Interior Light bulbs - What sizes ?
Hey, im broke this week and had a few dollars to fix the lights that are out on the car.
Could someone identify the size lights i would need to replace the front overhead bulb. Its a little tiny bulb thats in that top light in the center overhead in the front.
Also the side door lights?
And then the middle overhead light behind the front seats and in front of the back seats.
Just need to know what size bulbs to get for these. And will the to overhead roof lights and side door lights cover the whole car on the inside ?
Interior Bulb Numbers
License Plate: 168 or 194
Front Doorside: 168 or 194
Trunk: 158
Still looking for:
Front Overhead Map Light:
Dome Light: Could be 10 x 31 but still not certain. anyone know the map or dome for certain ?
Trunk: 158
Still looking for:
heres the pics of the overhead map lights, they are "hyper white" type color, they are awesome and MUCH better then the OEM lightbulbs imo
u can get them from www.optauto.com and they are PLG-m26 bulbs
hope this helps
hope this helps
i have been searching all around as well for the bulb number for my map light 97 maxima se. i have finally found the answer that there is NO direct replacement bulb that matches oem specs that you can buy OTHER than from the dealer. only the dealer has the original bulb that has the same light output. if you buy another bulb (same type) that fits from anywhere other than the dealer it will not be as bright or same light output. Now what many people do is buy an led replacement or other solution which is much cheaper. That works fine. there are many options but none for the same bulb type as the oem one or one that matches oem specs unless you go to dealer. i would check out this link
https://maxima.org/forums/4th-genera...ed-thread.html
rbaker100
Aug 28, 2015 08:11 PM
