What is Overdrive for and why should i leave it on or off?
when i got my 2k maxima se the dealer said to just leave overdrive on all the time. is he right? what is it for and will i notice any difference in performance if i leave it on or off?
experiment with it. i think my max accelerates faster with O/D off. I've been told that having O/D on keeps your RPMS lower to save gas, but my friend says that having O/D on makes your car shift at the peak torque points for optimal acceleration.
Originally posted by SebringS2k
Umm, I believe that Overdrive is actually your 4th gear, hence it being the overdrive gear...
Originally posted by ryanb860
i may be a newbie but i do know that's wrong.
Tell me how you know Sebring is wrong? Explain what OD is then! I am real curious to know.
OD is NOT fourth gear.......at least not on my 2k SE auto. there's 1, 2, D, N, R, and P. OD is activated by pressing a little button on the shifter.
Also, you can try counting how many shifts it takes for you to get up to freeway speeds.
There seems to be a lot of misinformation in this thread about overdrive. Marky3320, you are wasting gas if you leave it off most of the time.
Here are some articles on overdrive:
http://cartalk.cars.com/Columns/Arch...6/July/01.html
http://cartalk.cars.com/Columns/Arch...97/May/20.html
http://cartalk.cars.com/Columns/NEW_...tember/01.html
http://cartalk.cars.com/Columns/NEW_...tember/17.html
Please explain your reason for thinking the OD button is not to engage 4th gear.
With the exception of a few people, the amount of ignorance in this thread amazes me. Turning overdrive off essentially blocks out 4th gear, whether it is done with a button or sliding the shifter into "3" makes no difference. The first 3 gears will perform the same regardless if it is on or off, with the exception of 3rd eventually going into 4th that is.
REDinLV
Aug 15, 2024 12:30 AM
Kingofmaximas24
Nov 12, 2015 04:40 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
carid
Sep 17, 2015 05:00 AM
