MEVI Parts list - is it complete?
I just got a MEVI kit and I just want to make sure that I have all the parts before I go ahead and disassemble my stock manifold.
MEVI
MEVI collector cover (covers the 6 butterfly holes)
1 x Intake gasket Nissan p/n 14032-38U00
6 x power valve Nissan p.n 14513-38U00
9 x hex bolts Nissan p/n 08050-6205A
1 x shaft assembly (rod?) Nissan p/n 14512-38U00
1 x o-ring Nissan p/n 14515-40F00
1 x power actuator p/n 14517-38U00
Harlan RPM Switch
MAP BARO switch (from GM dealership)
Vacuum canister (half-cylindrical black plastic box)
2 x 10mm bolts to bolt the power actuator to the MEVI
1 screw which is currently an orphan
1 ground wire horseshoe connector (?)
Misc. wires connected to RPM switch and vacuum canister and relay fuse
Are there any other important major parts that I am missing here? Hope someone can help me out with part #s if necessary.
Thanks.
P.S. I would like to replace all gaskets in order to avoid potential problems later. Please recommend what else I would need.
MEVI
Harlan RPM Switch
Thanks.
Originally posted by Dave B
You forgot JWT ECU
Dave
You forgot JWT ECU
Dave
Yeah that's in the plans. I have a spare ECU here with the same production cycle date as my car. But I am contemplating whether I should send in my own ECU since I know it is in good shape or if I should send this other ECU.
Originally posted by aznsap
what's the purpose of the switch? sorry im new to the mevi. is it to turn the mevi on/off? what's wrong with leaving it always on?
Bump for some more input on any more needed parts....
Throttle body gasket 14120-38U02
EGR gasket 16175-31U01
14033 - 38U00
I think one of those 2 gaskets goes in between the butterfly holes and the cover. Correct me if I'm wrong.
14033 - 38U00
Originally posted by Shoooter_j
Can't leave it on all the time, otherwise you lose massive power below 5k rpm, hence the switch.
jholley
Aug 30, 2015 06:39 AM
Team STILLEN
Aug 10, 2015 04:29 PM
