where can i buy walbro fuel pumps for cheap???
Old May 12, 2003 | 09:41 PM
a33's Avatar
a33
please post some websites...
thank you
Old May 13, 2003 | 05:25 AM
Confused's Avatar
Permanent Maxima.org Resident
http://www.lightningmotorsports.com/index1.htm
Old May 13, 2003 | 06:27 AM
turbo97SE's Avatar
I can get them much cheaper! I'll PM you a price
Old May 13, 2003 | 06:57 AM
Jime's Avatar
http://www.autoperformanceengineering.com/
Old May 13, 2003 | 08:52 AM
KMax2988's Avatar
If ya don't mind, hit me up with a price too.
Old May 13, 2003 | 10:09 AM
LatinMax's Avatar
eBay is where I got mine.
Old May 13, 2003 | 02:32 PM
PCGuRu2K's Avatar
I need one for a 2001.. Anyone know the part# we can use?
Old May 13, 2003 | 03:34 PM
LatinMax's Avatar
Walbro GSS342 (High Pressure 255lph) is what you will need. I also have a write up on how to get it done on page 2 of my site.
Old May 13, 2003 | 03:59 PM
hlh0501's Avatar
$80 powertechimports.
Old May 13, 2003 | 04:28 PM
PCGuRu2K's Avatar
Do we need any rail fittings or anything? Or is just the fuel pump good enough?
Old May 13, 2003 | 06:58 PM
LatinMax's Avatar
pump only and that will allow you to run any kind of boost or juice.
Old May 14, 2003 | 10:13 AM
PCGuRu2K's Avatar
There are a lot of different part#'s for the GSS342
GSS342 (400-846)
GSS342 (400-865)
GSS342 (400-848)
GSS342 (400-730)
GSS342 (400-847)
GSS342 (400-883)
GSS342 (400-954)
GSS342 (400-765)
Anyone know exactly which one it is? Or it don't matter as long as it is the GSS342?
Thanks!
Old May 14, 2003 | 10:24 AM
KMax2988's Avatar
GSS342 (400-846)
GSS342 (400-865)
GSS342 (400-848)
GSS342 (400-730)
GSS342 (400-847)
GSS342 (400-883)
GSS342 (400-954)
GSS342 (400-765)
Thanks!
GSS342 is the fuel pump PN which is the one you want. In the parenthesis are PN's for install kits. For example, a Acura Integra will have different parts in the install kit then a DSM would.
Old May 14, 2003 | 11:28 AM
PCGuRu2K's Avatar
Ohh.. IC.. Thanks a lot!
Old May 14, 2003 | 07:51 PM
LatinMax's Avatar
Ya all that and they don't make one for our car. But you can use any of them. I think I used one for a Prelude or something.
Regardless what you use it will take some modifing to get it in. My write up will cover all of that.
Old May 14, 2003 | 07:57 PM
runelind's Avatar
When using an aftermarket fuel pump, doesn't the car run really rich at idle? I would think that a rising rate fuel pump would make more sense.
Old May 15, 2003 | 04:27 AM
PCGuRu2K's Avatar
It'll run rich at idle but then that's when I can use my cartech fpr and adjust it...
Old May 16, 2003 | 01:52 AM
a33's Avatar
a33
if you adjust the fp with the cartech fpr.... it is only one setting right?? or can you adjust it for every rpm??? cuz if you are running rich at idle and you adjust it with the fpr, you might not have enough during boost.....
and can i solve the problem with an safc after i install the fuel pump?
Old May 16, 2003 | 02:22 AM
Jer's Avatar
Jer
Yup. I believe you can go +/- 50% - so as long as you don't need to adjust your mixture by more than that, you should be fine.
Old May 16, 2003 | 05:54 AM
PCGuRu2K's Avatar
I just ordered the fuel pump today.. Do you guys think I should take it easy until I install the fuel pump or will it be ok since I'll probably have it installed in 2 weeks so I can beat on it now?
Old May 16, 2003 | 10:07 AM
LatinMax's Avatar
NO don't beat on it til you get the pump. If you are lean at boost you will detonate and blow something up. (hole in your piston, broken valve)
A33: "if you adjust the fp with the cartech fpr.... it is only one setting right?? or can you adjust it for every rpm??? cuz if you are running rich at idle and you adjust it with the fpr, you might not have enough during boost....."
your FMU should take care of your fuel issues at WOT or boost. That is why it is there.
Old May 16, 2003 | 10:08 AM
PCGuRu2K's Avatar
I replaced my FMU with the cartech FPR.. It has two adjustments. One for idle and another one for fuel pressure raise.. I'm running acutally rich now I think. Fuel delivery is not a problem. The only thing I fear is blowing my injectors..
Old May 16, 2003 | 10:13 AM
LatinMax's Avatar
That should not be a problem with the setup that you have. I think there are peps that are runnig more power than you and are not haveing injector problems.
Old May 17, 2003 | 10:02 AM
CASS98SE's Avatar
After you install the Walbro fuel pump, what are you supposed to do with aux. fuel pump ? Can you just leave it in?
Old May 17, 2003 | 10:49 AM
LatinMax's Avatar
NO, just remove it and save it. So that you can include it with the SC kit if you ever sell it.
Old May 17, 2003 | 06:06 PM
a33's Avatar
a33
so i dont need the fuel pump that comes with the charger after i install the walbro pump???
Old May 17, 2003 | 06:23 PM
KMax2988's Avatar
Nope. The walbro can handle it.
Old May 17, 2003 | 06:26 PM
CASS98SE's Avatar
OKay I understand that would just bypass the stillen aux. pump for the fuel line. How do you wire it? Do you have to run wires all the way back to the walbro or what?
Old May 17, 2003 | 06:30 PM
KMax2988's Avatar
http://home.earthlink.net/~msue2/Walbro.htm
Old May 17, 2003 | 07:34 PM
LatinMax's Avatar
Have you read my write-up Yet?
It replaces the factory fuel pump and plugs right in to the the factory harness.
Old May 17, 2003 | 08:59 PM
BigDogJonx's Avatar
One small thing that I will add, make sure you get a high pressure model if you are going to get one to get more flow at higher fuel pressure.
BkGreen97
Apr 2, 2016 05:47 AM
bumpypickle
Sep 20, 2015 08:22 AM
rnb754
Sep 14, 2015 11:39 PM
conansriver
Sep 11, 2015 10:26 AM
