what brake fluid do you use?
for some reason i do not have permission to use the search....
anyway, what kind of brake fluid do you guys use and why? i hear that motul600 stuff is good for autoxing, but that's if you change your brake fluid often, as i hear it absorbs moisture. i will have to change my brakes soon, so i was thinking of the ATE superblue stuff, since it absorbs moisture at a very slow rate. any recommendations and why? thanks.
If you flush your fluid periodically you should be fine with just about any Dot 3 fluid.
I use GUNK heavy duty Dot 3. My fluid get flushed with every brake job.
every brake job? do you mean when you change the pads?
btw.... how many liters/pints of brake fluid do i need to purchase if i'm flushing out my system and changing the brake lines/
Re: what brake fluid do you use?
I flush/refill my vehicles every 30 to 50k.....
-RMB
Re: Re: what brake fluid do you use?
Originally posted by rmb
Don't waste your money on the super-whoopie brake fluid with the stock brake system. Any regular name-brand DOT3 rated fluid is fine. I think I used Castrol last time.
-RMB
-RMB
Re: Re: Re: what brake fluid do you use?
cool thanks...... i still don't know how much brake fluid to go buy tho.
Go to your local auto store and buy any Dot 4 fluid if you don't want to spend more than $5. After you leak your brake fluid, just top off the new brake fluid. Pump your brake and go top off your fluid again. You don't have to know extactly how much to put in like oil and tranny oil. All you need to do is top it off to the line for the brake fluid.
I use valvoline synpower. Cheap and compares well to the expensive stuff:
brake fluid comparison
Re: Re: Re: Re: what brake fluid do you use?
Originally posted by iwannabmw
If you are going to autocross or drive the car hard, the ATE Superblue is perfect and well worth the money. I have yet to cook this stuff on the track. You will need to buy 2 liters.
Apr 16, 2020 05:15 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
