"scratching" sound on ignition start
Old May 15, 2003 | 01:58 PM
shobuddy's Avatar
I don't know about other cars but when I start my 03 SE Max, it makes a scratching sound for like a second right after i turn the ignition. This happened on my 91 sentra too. Havent' paid attentino to it on other makes/models but does anyone know what thats about?
Old May 15, 2003 | 02:35 PM
98maxsel's Avatar
its the starter.
Old May 16, 2003 | 05:43 AM
shobuddy's Avatar
so its on all cars?
Old May 17, 2003 | 12:03 AM
lophix's Avatar
it's the starter.
Old May 17, 2003 | 01:01 AM
juani's Avatar
Rockin' VK56!!
when i had same problem, mine was caused by belts
Old May 19, 2003 | 07:16 AM
mingo's Avatar
my starter has been acting up lately too, maybe the gear isn't retracting fast enough.. but as long as it still cranks i'm happy =D
Old May 19, 2003 | 02:39 PM
Ceasars Chariot's Avatar
Old Maxima Legend
mine2
Old May 19, 2003 | 03:07 PM
Eric L.'s Avatar
Does it happen immediately after the car has already started? If so, its the starter.
Old May 19, 2003 | 04:06 PM
Frank Fontaine's Avatar
Re: "scratching" sound on ignition start
Since you have an '03 just have the dealer take a look at it. It sounds like the starter, which is a known issue with the 4th gen, I didn't know the newer Maxes had the problem too. It could be belts too if there's moisture in the air but I doubt that's your problem. My car is 5 1/2 years old and about 6 months ago I too had that noise. Then I found from the motorvate website that the 4th gen starters had inadequate grease inside causing the drive shaft of the starter to get stuck. My problem went away once the temps warmed up--I'm sure it will be back by next winter. These parts are outrageously priced, I think over $300 in parts alone to get the genuine replacement, so I urge you to take care of it under warranty. From what I hear there is no true "new" starter, alternator, etc. as a replacement. They use various suppliers and they are of various qualities, but put it in a new box with the same part #. Good luck.
Old May 20, 2003 | 05:42 AM
shobuddy's Avatar
it happens immediately after i start and since it happened on the sentra too, i'm not too concerned. just was curious as to what it was.
thanks for all the replies.
Old May 20, 2003 | 07:44 AM
Dave B's Avatar
Not DAVEB the parts guy
My 96 has done it for over two years now. OEM starter.
Dave
Old Apr 11, 2007 | 05:43 PM
shobuddy's Avatar
Dave
http://www.nissanhelp.com/Ownership/.../NTB03-060.htm
rnb754
Sep 14, 2015 11:39 PM
TheMafia
Sep 4, 2015 08:26 AM
trungg86
Sep 4, 2015 04:58 AM
