Looking for Brake Pads
Well with 122,000 miles the front passenger pad started crying. Took the wheel off sure enough time to replace 'em. I'm thinking of picking up a set of stock pads from courtesy.
$57.01 - front
$43.19 - rear
Am I making a mistake by doing that? Should I be buying a different set then the stockers? I don't track the car, would perfer dust free, good stopping pads, quiet, that will last. So far the Nissan ones seem to fit the bill. Except $100.20 seems high to me.
Thoughts?
Oh btw... I have abs if that matters any.
$57.01 - front
$43.19 - rear
Thoughts?
please help me with this, i just got pads from courtesy nissan, and that whole you don't need the pins concept is kinda loosing me, why don't replacement genuine oem pads lack the holes for the pins?
Originally posted by Jeff92se
You might not need the rears. I took a look at mine rears @ 120k, and they were less than 1/2 worn.
Btw... I believe the stock pads to be semi metalic.
Actually you have to take the wheel off for the fronts also as the piston side caliper usually is worn more than the front side. The wonders of single piston calipers. BTW. I changed mine to some cheap Quiet Stops for like $35/fronts. I'm planning to install the 300z calipers at some point but these are pretty comparable to my metalmasters that I had before. These are less noisy also
Originally posted by Wizeguy
Dang so now I have to pull the rear wheels off too! I just put these wheels on too. I 'should' have looked. Grrr...
Already pulled off the fronts to have a 'look see'. They are due and yep the inside is on the noise maker, well was till I took the screw driver to it.
Wizeguy - See now its good for another 50,000 miles! hehe...
Apr 16, 2020 05:15 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
