Would I be insane to run my JWT ECU NA program with a 3.6 pullied SC?
Old May 27, 2003 | 09:02 AM
Dave B's Avatar
Not DAVEB the parts guy
I'm still debating about the SC (won't happen until Christmas time if I do) and I was wondering if I could get away with running my 7000rpm NA-tuned JWT ECU? The ECU tunes for A/F and advances timing at various places from 3500+rpms. On 92 octane and hot weather I've noticed no pinging which leads me to believe the timing really isn't advanced to far over stock. If I get the SC, I pretty plan on staying with the 3.6" pulley for the most reliability. So would I be crazy?
Dave
Old May 27, 2003 | 11:06 AM
Stephen Max's Avatar
Re: Would I be insane to run my JWT ECU NA program with a 3.6 pullied SC?
Dave
The SC fmu will override any afr tuning provided by the ECU, but the advanced timing is something to worry about. Maybe you can find out from JWT how much the timing is advanced and at what rpm range? If the timing is only advanced in the midrange and left alone at high rpm, then you'll be okay at high rpm where you make maximum boost. Might be a great combination.
Old May 27, 2003 | 11:12 AM
Jeff92se's Avatar
I'm needing a caw
Advanced timing + boost = BOOM. JWT provides programed ecus for boosted 3-gens. They can probably reprogram yours for SC boost also. Shouldn't be that expensive. I "hear" $100 or so?(provided you bought their ecu already). If you do this, you can eliminate the need for the boost referenced FPR. JWT can adjust the fuel injector pulsewidth instead of just ramping up the fuel pressure. Depending on the boost levels, you might need bigger injectors.
Old May 27, 2003 | 12:16 PM
Brodaiga is running 13 psi boost and advanced timing provided by a JWT ECU, along with 300zx injectors. Might want to pm him.
http://forums.maxima.org/showthread.php?threadid=218674
Old May 27, 2003 | 01:05 PM
Nealoc187's Avatar
SLOW
Re: Re: Would I be insane to run my JWT ECU NA program with a 3.6 pullied SC?
JWT told me they'd reprogram an existing JWT ECU for $100, this was back last year.
Old May 27, 2003 | 01:55 PM
Dave B's Avatar
Re: Re: Re: Would I be insane to run my JWT ECU NA program with a 3.6 pullied SC?
Hopefully they'll honor that. $100-150 sounds reasonable to me since I already gave them $580. I'm sure all they have to do now is literally plug it it and upload the "SC program".
Are you still thinking about the SC route?
Dave
Old May 27, 2003 | 07:09 PM
MardiGrasMax's Avatar
I wouldnt do it, just aint worth it with out some protection like a J&S But the JWT is plug and play, J&S is not.
Old May 27, 2003 | 07:30 PM
mtrai760's Avatar
'Trynna' is not a word
I wouldnt do it. Not worth the cost of a new engine. I know JWT had problems with its S/C program at first too, so I deffinetly wouldn't use the NA program with boost...
Old May 27, 2003 | 08:44 PM
Nealoc187's Avatar
SLOW
Re: Re: Re: Re: Would I be insane to run my JWT ECU NA program with a 3.6 pullied SC?
Dave
No I think I am going to stay N/A and see what this motor can do if I crack it open.
Old May 27, 2003 | 11:03 PM
Nismo87SE's Avatar
Since you have a JWT ecu ditch the FMU and other bandaids all together. Just get some 370cc injectors and have the ECU reprogrammed for 3 or 4 bar fuel psi + 370cc injectors. Your car would detonate at part throttle with a NA ecu vs a programmed one. Since JWT has tuned I30krab's car, the SC program should be pretty good right out the box. It probably won't make as much power as Mardi got out of his car, put it's plug/play and you don't have to worry about tuning it.
Dave
Old May 28, 2003 | 05:54 AM
Matt,
What does the J&S do above and beyond what the OEM knock sensor does? Does it come with its own KS or do you tap into the OEM one? Does it require dyno tuning? Sorry for all the questions, but it sounds like a good thing to have, maybe.
Old May 28, 2003 | 08:19 AM
OE knock sensor is ignored by the ECU at WOT.
www.jandssafeguard.com for all the info...
Originally posted by Stephen Max
Matt,
Old May 28, 2003 | 08:25 AM
JAY25's Avatar
yes he is you are correct!
Old May 28, 2003 | 08:39 AM
So is he running a SC program ECU or a NA program ECU?
QueensMAX
Sep 15, 2015 04:14 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
ballerchris510
Sep 10, 2015 09:35 PM
mix master
Sep 4, 2015 05:50 PM
