Best synthetic oil to get?
Old May 28, 2003 | 10:49 PM
meccanoble's Avatar
Sports Button FTW
i'm due for an oil change and i'm going synthetic for the first time ever. I'm gonna try install myself. Anyone got a write up? it seems self explanator except for where u unplug from underneath the car.
I just need to know that and the best or most recommended synthetic oil to get for the money and how much i need and best oil filter to get. And best place to get it.
As far as directions, i see it as:
1) lift car
2) open oil cover from up top
3) put pan under car
4) drain oil
5) take filter off, put new filter on
6) close plug used to drain from underneath
7) fill with new oil and close
just one OTHER question. When the car is lifted, wont it pour out at an angle? so isnt there a chance i may mix the new oil wit left over old oil?
Old May 28, 2003 | 10:51 PM
Jeff92se's Avatar
I'm needing a caw
Your kidding right? How long have you been on here?! geez
Old May 28, 2003 | 10:57 PM
nadir_s's Avatar
vicodin ... gift of life
also, frank's website is your friend. www.motorvate.ca ... pic by pic instructions.
before going synthetic, u should flush your engine.
filter: nissan (the model # that starts w/ a 9 ... can't remmeber the rest. the newer one is not as good...)
oil: i PREFER mobil 1... why? i dunno, i just know that it's been put in the car ever since it was bought brand new 7 years ago.
Old May 29, 2003 | 05:59 AM
ThurzNite's Avatar
depending on how wide your oil catch pan is, you might need to put the plug back in before working on the filter. Also, have a can of brake cleaner (get the one that's safe for rubber and plastic) handy. When you're all done, spray the bottom of the oil pan down and any other gunk down there. It's a cheap and easy way to track leaks.
Jae
Old May 29, 2003 | 06:12 AM
StygianMax's Avatar
Re: Best synthetic oil to get?
You should dip your finger in some clean oil and apply it to the gasket of your new filter before putting it on.
Old May 29, 2003 | 06:56 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Best synthetics are in this order:
Amsoil Series 2000 0W/30
Amsoil 5W/30
Mobil 1 SuperSyn 5W/30
Old May 29, 2003 | 03:54 PM
Confused's Avatar
Permanent Maxima.org Resident
replace copper crush ring on the oil drain plug.
Old May 29, 2003 | 03:57 PM
Battle Max's Avatar
Im running royal purple i just put it in 2 weeks ago and i love it.
Old May 29, 2003 | 03:59 PM
190hpKiLLA's Avatar
Granny Driven
Mecca are u always looking for a way to fukc up ur car.
U have over 130K miles, why da fukc would u wanna switch to synthetic?
Ur car might start leaking oil and sh iT. It drives perfect with normal oil so why fock with it???
Damn I hate to see my car broken.
Old May 29, 2003 | 04:02 PM
James92SE's Avatar
2 VE's are better than one!
'try the install yourself'?
What is this a turbo kit?
Old May 29, 2003 | 04:19 PM
MrGone's Avatar
why lift the car? it takes more time
you dont have to open the oil filler cap, it just prevents the "glugging" when the steady flow of oil comes pouring out.
I normally use Valvoline or Castrol for my oil changes, and AmsOil for everything else. Today I flushed the Durangos transfer case and filled it with 1.2l of AmsOil ATF, and now when I drive in circles in 4wd, my inside rear wheel squeels, while before it would just chirp (btw, it is locked).
MrGone
Old May 29, 2003 | 05:46 PM
DigitalTexan2u's Avatar
Ignorance to the benefits of synthetic amazes me yet again...
Old May 29, 2003 | 05:48 PM
Amsoil 5W/30
Yup...I agree 100%
I use this:
Old May 29, 2003 | 06:00 PM
nadir_s's Avatar
he has a point... switching to synthetic which is thinner oil does have that slight risk of running leaks on high mileage cars.
Old May 29, 2003 | 06:11 PM
Conventional oils actually shrink gaskets over time...synthetics do not. Ever notice how many cars have oil leaks? Around gaskets?
Car A with regular motor oil used forever will leak oil before car B with synthetic.
Old May 29, 2003 | 07:43 PM
nadir_s's Avatar
yeah ok but HIS CAR has been running on regular oil for 130k miles... so his gaskets have shrunk over the time. NOW he puts synthetic which is thinner (can seep out quicker)... get it?
Old May 29, 2003 | 07:48 PM
StygianMax's Avatar
Why is that?
Old May 29, 2003 | 07:58 PM
do some research...synthetics actally permiate gaskets and don't break them down. Over time they will cause gaskets to maintain their original thickness...or possibly cause them to expand somewhat.
Got it?
Old May 29, 2003 | 08:18 PM
nadir_s's Avatar
Got it?
aklsjfd;aklsjf;aksdj;asfja;slkjfas;dlfkjas;dflkjas df;kjasdf;asjdfaa;dslfjads
alright 1 more time...
130k miles of regular oil = "shrunk" gaskets (according to what you are saying)
synthetic oil = thinner oil
shrunk gaskets + thinner oil = POSSIBLE LEAKS
and that is why people say you risk having leaks when switching high mileage cars to synthetic oil. You've explained the gasket shrinking theory yourself. Now apply your own logic to mecca's situation. Simple as that.
Old May 29, 2003 | 08:23 PM
StygianMax's Avatar
So do you mean to say that a synthetic 5W30 is thinner than a dinogoo 5W30?
Old May 29, 2003 | 08:59 PM
nadir_s's Avatar
thinner... less viscous... seeps through **** faster than dinogoo, yeah, so i've heard alot. I don't see why else people say switching to synthetic on high mileage cars could cause leaks.
Old May 29, 2003 | 11:07 PM
meccanoble's Avatar
Sports Button FTW
hey guys, i went through the synthetic change, actually got 10w30 because of the hot season. The shop recommended it. If i do see some leakage, i'll switch back unless u guys recommend something else but i have faith in the car. 190hpkilla, i wont let anything bad happen to MY car . I am trying to do something better for it.
Old May 29, 2003 | 11:12 PM
meccanoble's Avatar
Sports Button FTW
i've been on the org for about a year now. If you guys would kindly leave the search menu open for all, i would have looked this info up but nooooooo i gotta waste bandwith . I never researched it because i never did it.
Old May 29, 2003 | 11:34 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Just to clarify:
If you run dino for a long enough period of time, a false seal of sludge/slime will build up allowing your seals to dry up and shrink/crack. Then when you switch to synthetic, the added detergents in the synthetic will break down the false seal and ANY oil will leak out.
The viscosity of dino vs. synthetic doesn't cause leaks. Old myth.
Old May 30, 2003 | 12:02 AM
nadir_s's Avatar
oh ok, thanks for clarifying.
Old May 30, 2003 | 12:15 AM
IceY2K1's Avatar
Yeah, I too believed the same myth. Then someone HERE edumacated me.
Credit: Bill or iwannabmw
Old May 30, 2003 | 12:39 AM
ThurzNite's Avatar
If switching to synth is bad cuz it's thinner, why can't you use a thicker oil? Mobil1 is offered in 10w-30 and 15w-50.
My 1993 Altima had 155k miles on it, all crappy dino oil from Firestone from previous owner. When I got the car, I switched over to mobil1 ...idles better, smoother acceleration, and possible improved fuel efficiency. No leaks either.
Jae
Old May 30, 2003 | 01:05 AM
IceY2K1's Avatar
Jae
Did you see my "false seal" post above?
Old May 30, 2003 | 05:17 AM
StygianMax's Avatar
Just to clarify:
Does the drying of the gaskets happen from the "non sealed side" i.e. outside? As you describe it, it sounds to me that there an "insulating" barrier that prevents the oil from keeping the gasket moist and pliable.
That's what I figured. An oil that's given a viscosity rating of 5W30 has those associated viscosity properties regardless of how it was made (au naturel dinogoo or synthetically processed). In short, dinogoo oil that's rated at 5W30 is not any thinner nor thicker than synthetic 5W30.
Old May 30, 2003 | 07:10 AM
meccanoble's Avatar
Sports Button FTW
waht does viscosity mean?
Old May 30, 2003 | 08:31 AM
Jeff92se's Avatar
I'm needing a caw
Leaks from synthetics are because their molecules are more uniform in size vs all over the place in dino. Nadir, synthetics are not thinner or thicker than their respective dino oils. 5w30 is 5w30. No matter the type.
Old May 30, 2003 | 09:01 AM
bill99gxe's Avatar
What is oil? Does anyone know?
Old May 30, 2003 | 09:04 AM
Jeff92se's Avatar
I'm needing a caw
I hear someone wrote some shat about oil but I forget who?
Old May 30, 2003 | 10:55 AM
190hpKiLLA's Avatar
Granny Driven
So it is safe to switch to Synthetic?
Old May 30, 2003 | 10:58 AM
StygianMax's Avatar
Something like this: the ability of a fluid to resist flow through it. Viscous fluids contain longer molecules that "tangle up" with one another and that slows down a object trying to travel through it. Viscosity is also affected by temperature. The higher the temp., the lower the viscosity.
Fluid density is something completely different! Viscosity and density are not related.
This is the good stuff I learned from my gr. 4 son who had a science fair topic on this.
Old May 30, 2003 | 11:53 AM
IceY2K1's Avatar
Yes, the rubber seal is "blocked" from contact with the crankcase oil by the sludge false seal. Oil keeps a seal pliable and even swollen, but once it dries up, it shrivels and cracks. Then once it comes in contact with ANY oil, it will not provide a seal.
At 130K miles, I'd stick with regular dino. The increased longevity of the synthetic at that point is probably not going to offset the cost of paying a mechanic to replace the main seals.
Synthetic is great stuff to PREVENT wear on engine parts, but by 130K it's pretty much too late to make a difference in engine life.
Old May 30, 2003 | 01:34 PM
190hpKiLLA's Avatar
Granny Driven
And his car doesnt leak oil, i know cause it used to be my car. So why fock with it. Just use normal oil.
Do you what a car does when he is bored? Scratches his ballz.
Mecca if u have nothing to do go scratch ur ballz and not ur car.
Old May 30, 2003 | 01:35 PM
StygianMax's Avatar
Thx for the detailed explanation. That was great!
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
