manifold gasket problem...pics
Old Jun 2, 2003 | 11:37 PM
jdmmax's Avatar
ok so i was changing my spark plugs sunday and i noticed a problem.
the intake manifold gasket, the ruber one between the upper and lower plenum was poping out a little bit. it was poping out on the two middle runners. i was able to see the makes on the rubber gasket where the manifold accually clanpped down at. it was wierd i just pushed it back in but i think if i boost again it will pop out again.
anyone see this happen before. i didn't take any pictures cause it
totaly forgot i just pushed it in.
any ideas ???
here is a picture
on my web sight please take a looky.
http://fastforward.lchu.net
note the shinny oily like substance all over the gasket. well i have that stuff alll alone the gasket. it seeps into the manifold and collects dust.
car seems to run ok but i cannot get past .67hkpa of boost.
me and slammed are suppose to work on the car this saturday but i would like any other suggestions.
like what is that oily substance cause it does not smell like motor oil.
Old Jun 3, 2003 | 03:28 AM
Bags's Avatar
VG Ridah's Biatch Hoe
hmm looks like the gasket may be torn..
take off the manifold and check the gasket, getting a replacement is gonna suck I bet
Old Jun 3, 2003 | 04:47 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
courtesy has it.... i think my buddy paid under 30 for his.
Old Jun 3, 2003 | 05:26 AM
ejj's Avatar
ejj
Re: manifold gasket problem...pics
Its normal to have a little oil in the intake manifold. The crankcase vent. hose vents some oily-air back into the intake path.
Old Jun 3, 2003 | 06:26 AM
Confused's Avatar
Permanent Maxima.org Resident
hard to see the second pic.. can you see past the gasket edge to the chamber hole (middle) of the gasket?
Just a thought, you won't know if its ripped until you loosen the manifold so you might as well have a new one handy and swap it out regardless. its really not that bad of a job.
Old Jun 3, 2003 | 03:51 PM
jdmmax's Avatar
ok i got a gasket hehehehe paid 3 bucks.....
now i have a breather coming off the crank case vent on the front valve cover.
i see another vent comming out of the rear valve cover right behind the tb and it hooks up to a hard line to the top off the main intake runner from the tb. could that be the oil bandit.
anyways andy im doing this ish tonight. if you are able to swing by and lend a hand that would be great hit me up.
Old Jun 3, 2003 | 04:02 PM
Battle Max's Avatar
Frank that looks like the same oily crap that i have on my manifold also remember me showing you. I have to take a look at my gaskets too.
Old Jun 3, 2003 | 04:17 PM
jdmmax's Avatar
yup it accually is but you have a puddle hahahahaha i have it all up on my gasket.
Old Jun 3, 2003 | 04:20 PM
Battle Max's Avatar
well that explains alot 99's fall apart
Old Jun 3, 2003 | 04:22 PM
jdmmax's Avatar
im sorry wasn't it a 95 5spd down for like 6 months with no idea what was going on????????
Old Jun 3, 2003 | 04:28 PM
Battle Max's Avatar
Yea i knew what was wrong it was a problem with my clutch...something you dont know about
Old Jun 3, 2003 | 05:05 PM
jdmmax's Avatar
well while you were crying about not having your maxima to drive i still had mine running. oh yeah didn't you but some v6 auto camaro to fill the void??????
Old Jun 4, 2003 | 01:09 AM
jdmmax's Avatar
yaaaaaaaay its fixed thank you slammed95 and 1fstmax for lending a hand.
so it turns out that the gasket riped on the part in between the middle two runners. the rest of the gasket showed signs off chapping as well. and the runners smelled like gasoline to when we removed it. i think slammed95 commented that his did not smell like that.
Old Jun 4, 2003 | 03:34 AM
Bags's Avatar
good deal.. glad you got it fixed
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
JonBlz
Oct 5, 2015 06:02 PM
dshinn
Sep 26, 2015 08:07 PM
