Power Antenna problems
What does everone do about a bad antenna. Posted a thread a week ago and response was to buy a stock antenna. Checked it out and a Nissan antenna is $250!! A replacement from Auto Zone would require a real hack job to install. The factory unit has a 2-prong power plug and a 3-prong connector for the "timer" (not sure what this is). Has anyone had any luck with the ones on e-bay.
here is the deal about the antenna...You dont buy the whole unit. Usually the mast is all thats broke or the plastic piece that pulls it up and down broke. If that is the problem then go here for instructions on replacement of the mast. You can pick them up from the dealer fairly cheap ($25 or so)
I have put an aftermarket antenna in 2 of my maximas before I ran across the org and found out about just getting the mast. I just found what wires were power and the signal from the radio to hook it up. It turned out nice and you cant tell its not factory.
I say get the mast and read the link I posted and fix the factory antenna.
good luck
good luck
lowpost99
Oct 26, 2025 06:53 PM
markevans999
Sep 10, 2015 04:29 PM
Violator
Sep 9, 2015 10:14 AM
trungg86
Sep 4, 2015 04:58 AM
