? for those with camber plates or real coilovers.
Old Jun 18, 2003 | 04:48 AM
redmaxpa007's Avatar
i SeE what you did therE
Re: ? for those with camber plates or real coilovers.
Originally posted by slammed95
I'm considering buying a set of Stillen camber plates, but have just one concern. I noticed that the adjustable plates are attached to the strut tower plate with 4 rather small hex bolts. Has anyone experienced any loosening or movement?
My worry is that when cornering hard, a lot of shear force is applied to those 4 little bolts, and that the camber will move.
Has this happened to anyone?
if you could do that i would be impressed. i have never heard of someone breaking those bolts those . those bolts just hold your alignment settings
Also, is there a noticable increase in suspension firmness from replacing the mushy rubber in the strut mount with the spherical bearing?
donno
Old Jun 18, 2003 | 06:21 AM
Dreizehn's Avatar
Mine have never moved...
Old Jun 18, 2003 | 12:38 PM
Turbo95Max's Avatar
Turtle turtle... Moderator
never heard of or had mine come loose before. As for the upper pillar ball mount, it does transmit a bit more road noise into the cabin, somewhat noticeable.
Old Jun 19, 2003 | 05:00 AM
PCGuRu2K's Avatar
I never had my bolts come off at all. They just hold the adjustments.. But then again my camber plates are attached to my coilvers
Old Jun 19, 2003 | 05:13 AM
Confused's Avatar
Permanent Maxima.org Resident
considering cattman's old setups only has two little screws and I have never heard of anyone having trouble with them, I think you're fine with four.
Old Jun 19, 2003 | 05:38 AM
96BLUMAX's Avatar
Where did you guys that have the stillen plates buy them? And for how much?
Old Jun 19, 2003 | 05:51 AM
PCGuRu2K's Avatar
Stillen plate are expensive.. You can get them either Stillen or call Southwestautoworks. Any place can order them for you. The usually get 20% off what stillen lsits.
knight_yyz
Nov 1, 2015 01:34 PM
fx4five
Oct 1, 2015 04:58 AM
