Maxspeed w/stock strut...check tire
Old Jun 20, 2003 | 07:37 AM
2k2max's Avatar
Strange ^
I've notice excessive tire wear on the insides of my tires. It seems to be more apparent in the front.
I've got about 20K on my Maxspeed w/stock strut, tires, and rim. I had the alignment done 3 weeks after the installation and noticed wear in the front about 3 months after. I had the local shop check the alignment, but they said it was within spec??
I now notice the fronts are wearing again on the inside. Depending on the road condition, the ride does bounce under moderate or heavy load. Is this bouncing what is causing the inside wear??
Does anyone else have this problem? any suggestions??
2k2max
Old Jun 20, 2003 | 07:39 AM
NT2SHBBY
no problems..I had an alignment done the same day my maxspeeds were installed....I don't drive the car alot but no uneven wear that I can see...
Old Jun 20, 2003 | 07:44 AM
2k2max's Avatar
Thanks for the reply.
I assume you installed the springs on 03/20/03. I've got about 8 months and 20K on mine and did not notice any excessive wear until 3 months later (but I do travel alot).
Keep an eye on your front...
Old Jun 20, 2003 | 07:46 AM
NT2SHBBY
Keep an eyes on your front...
actually they were installed about 2 months ago....
I have put maybe 2000 miles on the car since then
Old Jun 20, 2003 | 08:03 AM
mingo's Avatar
that's odd, i have had my maxspeeds on for a very long time and i never had uneaven tread wear.
Old Jun 20, 2003 | 08:08 AM
2k2max's Avatar
Should I take it to a different shop to have the alignment checked? Maybe the original shop did not want to fool with adjusting or even admiting the specs were off? They did show me a 4 wheel analysis sheet that seems to be legit.
There's really nothing shady about this shop, I just don't trust shops sometimes....Just like everything in life, it depends on the time, day, and mood.
Old Jun 20, 2003 | 08:11 AM
jjs's Avatar
jjs
At this point in time it certainly wouldn't hurt.
Old Jun 20, 2003 | 08:23 AM
njmaxseltd's Avatar
Post your alignment specs. I bet your running slightly into Negative Camber.
Old Jun 20, 2003 | 08:26 AM
2k2max's Avatar
I don't have them with me now, but I do recall something like "-1/8" and "-1/4". I don't remember.
Does this make sense to you? Do I assume "0" is perfect. Could I get them to adjust it more?
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
