Maxspeed w/stock strut...check tire
Strange ^
I've notice excessive tire wear on the insides of my tires. It seems to be more apparent in the front.
I've got about 20K on my Maxspeed w/stock strut, tires, and rim. I had the alignment done 3 weeks after the installation and noticed wear in the front about 3 months after. I had the local shop check the alignment, but they said it was within spec??
I now notice the fronts are wearing again on the inside. Depending on the road condition, the ride does bounce under moderate or heavy load. Is this bouncing what is causing the inside wear??
Does anyone else have this problem? any suggestions??
2k2max
2k2max
Originally posted by NT2SHBBY
no problems..I had an alignment done the same day my maxspeeds were installed....I don't drive the car alot but no uneven wear that I can see...
![got me](https://maxima.org/forums/images/smilies/ne_nau.gif)
I assume you installed the springs on 03/20/03. I've got about 8 months and 20K on mine and did not notice any excessive wear until 3 months later (but I do travel alot).
Keep an eye on your front...
Originally posted by 2k2max
Thanks for the reply.
Keep an eyes on your front...
I have put maybe 2000 miles on the car since then
Originally posted by mingo
that's odd, i have had my maxspeeds on for a very long time and i never had uneaven tread wear.
There's really nothing shady about this shop, I just don't trust shops sometimes....Just like everything in life, it depends on the time, day, and mood.
Should I take it to a different shop to have the alignment checked? Maybe the original shop did not want to fool with adjusting or even admiting the specs were off? They did show me a 4 wheel analysis sheet that seems to be legit.
Originally posted by njmaxseltd
Post your alignment specs. I bet your running slightly into Negative Camber.
Does this make sense to you? Do I assume "0" is perfect. Could I get them to adjust it more?
