FPR question
Old Jun 20, 2003 | 02:47 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
FPR question
I'm temporarily switching down to the oem fpr; will my top fuel pressure be affected?... With the sard, i'd hit around 100 psi or so.... can the stock fpr flow that much?
Old Jun 20, 2003 | 03:03 PM
[maxi-overdose]'s Avatar
FMU will take over the FPR once the boost kick in.
http://forums.maxima.org/showthread....ht=fmu+AND+fpr
Originally posted by Stephen Max
Since the fmu is in series with the fpr, whichever is set for the higher pressure is the one that controls the fuel pressure. So at 1 psi, if the fpr is set at 43 psi for instance, and the fmu is set at 28 psi, then your fuel pressure is going to be 43 psi. Once the boost pressure gets high enough to where the fmu is producing 43 psi, then it starts to control the fuel pressure.
Old Jun 20, 2003 | 03:06 PM
turbomax97's Avatar
I know that the fmu regulates the pressure once boost kicks in, but that base f/p still affects what you see at full boost....
so what's the max flow rate on the oem...
Old Jun 20, 2003 | 04:53 PM
sx7r's Avatar
it'll flow 100psi+. gone way past that when i was on spray.
Old Jun 20, 2003 | 06:38 PM
turbomax97's Avatar
.... it woulda been much easier if i just thought to call ya thomas hehe...
Old Jun 20, 2003 | 10:07 PM
sx7r's Avatar
well, free posts for both of us.
Old Jun 21, 2003 | 03:25 PM
turbomax97's Avatar
HAHAHA... greatest thing happened today...
My fpr started working fine, I took it out and ran air through it... it's working like a charm again... this leads me to believe something small may have been getting caught in the line or something... who knows...
Old Jun 21, 2003 | 11:34 PM
sx7r's Avatar
good deal
Old Jun 21, 2003 | 11:42 PM
KLoWnPR109's Avatar
still need the part?
Old Jun 22, 2003 | 11:58 AM
turbomax97's Avatar
Paul, it'd be great if you could still pull it.... thomas, i'm gonna do the aem anyway, sard is fine up top, but it still does the pressure flipping, although you CAN adjust it at idle...
Old Jun 22, 2003 | 10:46 PM
sorry~ didnt read your question clearly. I am pushing 100psi+ at WOT, peak boost.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
