Made a change to car...seems safe enuff
Old Jun 24, 2003 | 05:26 PM
WizzaMax's Avatar
So after having intermitent squeeks from the pullies for a while...last night about midnight-thirty...as I am gfetting started to come home...that sqeek became a scream liek a banshee...
and I figured out that the cleaning I did of the area with the brake cleaner must have had a negative effect on the bearing in the pulley...
I had some trouble before with rubbing tensioner but that was an easy fix...so I pulled the ASP one off and put the Stillen plastic pulley on ..
it is running very quiet now..and I am glad...it was embarrassing as hell to have the car make so much racket.
so I need to search around for more bearings for the pulley now...I will look thru the posts later to find them...I know they are here...
Old Jun 24, 2003 | 05:31 PM
Chunger's Avatar
My other car is a Hybrid
Just take the ASP in to a Car Parts store and they can read the PN# off the old one... Just need to take the C-clip retainer and it should pop out.
Old Jun 24, 2003 | 10:22 PM
WizzaMax's Avatar
Well much to my dismay the noise returned so I checked the tension on the belt and found the source of the problem is not a pulley after all it is oil from the return hose I surmise is seeping out and getting on belt...
therefore the noise is the oiled belt slipping all over and getting on my last nerve...to clean it and check it obviously requires another blower removal...ugh...at least I am getting good and fast at it.
captchaos
Mar 15, 2016 12:18 PM
bumpypickle
Sep 20, 2015 08:22 AM
Maxima Pride '07
Sep 12, 2015 07:29 AM
ag90fox
Sep 9, 2015 12:22 PM
-ReLLiK-
Sep 8, 2015 12:02 PM
