2k3 6speed tranny - Interesting
Well after about 13,500kms on the tranny on stock fluids,
Its notchier than ever, grinds in 2nd and 3rd, and 1st gear is getting harder to shift into..
Seems like its going back to how my 2k2 used to be..
How are your 2k2/2k3 trannies like?
ED
ED
Mine has ~5700 miles on it w/original fluid. It's actually gotten much smoother over time, and is now virtually notch-free (and no grinding whatsoever in any gears) *** knock on wood ***
It used to be hard to get into 1st gear if I was going anything but almost 0mph, but it's gotten easier as well.
Overall, I'm satisfied with the feel of the gearbox right now. I don't even feel the need to switch to Redline or anything like that.
Not surprising....
Considering I had my OEM MT fluid tested at 15K and it wasn't good, ESPECIALLY considering the 5spd holds 4.5qts. vs. your 2.5qts. or whatever.
I'd change it out IMMEDIATELY if I were you. Amsoil or MT-90, but I've read more positive reviews on the Amsoil in the 6spd..
Re: 2k3 6speed tranny - Interesting
ED
ED
Synchroshift II is a bit on the overkill side, as regular Synchroshift is just fine, but I am picky.
2K2, 9500 miles. OEM fluid. Smoother than when new. 3rd goes in fine now. Once in a while, hard to get into first, but not a big issue. I'll stick with dino oil when I change. That's what's recomended. There were threads about synchro problems when using synthetic in the 2K2's.
ED
ED
fluid soon (amsoil) with my next synthetic change
i toasted my first tranny. i had redline MT-90 in it from 1000 miles too.
I used Redline in the second one and it's good now at 12K but i sold the car. The tranny never was a good part of the car. always notchy, never totally smooth. hopefully the G will be better. if it ever gets here.
steve, my brother has a 6spd g35coupe...
they've all been having the same tranny issues...
same gas pedal being stuck issues...
same brake issues...
same rattling issues..
same hood issues
the only thing going strong seems to be the motor =]
same hood issues
MY 2k3 6 speed is blown. with 5000 miles it started to give up. In dealer being replaced this week.....still i think nissan cuts corners on tranny and a few other peices of the powertrain equiptment. the tranny they sent to replace mine was in a wooden crate... when it was opened the bell housing was cracked and part of it was broken off..
WHEELMAN
WHEELMAN
EDIT
turns out the bell housing wasn't the problem on the new tranny nissan sent. the place there the speedo gear goes into the casing sticks out away from the tranny and was broken off which in turn cracked the entire tranny case all the way around.
WHEELMAN
WHEELMAN
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
