Simple Turbo Question
Old Jul 9, 2003 | 11:24 AM
AgaricX's Avatar
I've been debating forced induction for awhile. I completely understand supercharging, but I'm much more interested in turbos. The performance and customizability definitely outweigh the extra hassle.
Question is... is there an air-flow diagram I can look at to help me design an intercooled system?
I found this... but can't determine the flow.
Is there a site with good information as to the pros and cons of certain turbo configurations. (IE: oil return, MAF placement, BOV recirculation vs not... etc...
I'm mostly concerned with turbo choice. AR ratings, compressor size etc...
Thanks for the help!
Old Jul 9, 2003 | 11:43 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Here you go.
Old Jul 9, 2003 | 11:47 AM
Jeff92se's Avatar
I'm needing a caw
If you can't understand the flow, I'd continue the research before jumping in. BTW, that's ALOT of unnecessary tubing just to retain the stock Y config IMHO.
Old Jul 9, 2003 | 12:43 PM
sx7r's Avatar
Originally posted by Y2KevSE
Here you go.
you don't say...
Old Jul 9, 2003 | 01:47 PM
Y2KevSE's Avatar
Originally posted by sx7r
you don't say...
Fo' shizzle...
Old Jul 9, 2003 | 03:44 PM
AgaricX's Avatar
It looked like a helluva lotta metal. My wife's GSX has MUCH less piping than that.
I'm most in awe of sx7r's setup. Do you have a writeup?
Old Jul 9, 2003 | 03:52 PM
sx7r's Avatar
sorry bud, no pretty diagram here. just ask me if you've got questions.
Old Jul 10, 2003 | 05:38 AM
96BLUMAX's Avatar
How would you suggest doing the downpipe to get the exaust to the turbo?
Old Jul 10, 2003 | 06:19 AM
Stephen Max's Avatar
What I like about his (s7xr's) setup is that the type of intercooler he uses keeps the intake air away from the hot engine and exhaust manifold. Every other setup I've seen routes the cool air coming from the intercooler back over the front exhaust manifold, heating it back up a little. But the 180 degree turn the air has to make in the intercooler may produce a larger pressure drop than the straight through designs.
Old Jul 10, 2003 | 06:44 AM
96BLUMAX's Avatar
I got the intake part down but i need to know my options for the flow of the exaust. Anyone?
Old Jul 10, 2003 | 11:16 AM
Bags's Avatar
VG Ridah's Biatch Hoe
not mine
But that is about the ONLY thing I like about it and everything else is AFU
Old Jul 10, 2003 | 11:47 AM
sx7r's Avatar
Quite the opposite, actually. The reason i went with the top to bottom intercooler was to combat pressure drop that you'd normally see in a side to side flow intercooler. The lower pressure drop from a top to bottom intercooler than a side to side is due to the following. Given the same frontal area on both types of intercoolers, the top to bottom intercooler has a significantly greater internal flow area because there are more tubes for the air to travel through which means less restrictions. Side to side intercoolers have fewer, longer tubes - meaning less internal flow area and larger pressure drop as a result. In this case, the direction of flow on the end tanks is not important because it's not a restriction and therefore does not cause a pressure drop.
You can also look at flow charts for specific intercooler cores. I don't know what everyone else is using, but according to Griffin, my intercooler is 90% efficient at 600cfm, which is almost right on with what i'm running right now. 14psi puts me at about 570cfm.
Old Jul 10, 2003 | 11:50 AM
sx7r's Avatar
Originally posted by bags533
not mine
we can start a club then.
Old Jul 10, 2003 | 05:30 PM
Bags's Avatar
you DO NOT WANNA be in the same club as me... yor set up looks to good compared to MY POS..
but thanks
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Unclejunebug
Apr 2, 2016 05:42 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
Socalstillen
Sep 26, 2015 12:01 PM
