Simple Turbo Question
I've been debating forced induction for awhile. I completely understand supercharging, but I'm much more interested in turbos. The performance and customizability definitely outweigh the extra hassle.
Question is... is there an air-flow diagram I can look at to help me design an intercooled system?
I found this... but can't determine the flow.
Is there a site with good information as to the pros and cons of certain turbo configurations. (IE: oil return, MAF placement, BOV recirculation vs not... etc...
I'm mostly concerned with turbo choice. AR ratings, compressor size etc...
Thanks for the help!
Originally posted by AgaricX
It looked like a helluva lotta metal. My wife's GSX has MUCH less piping than that.
I'm most in awe of sx7r's setup. Do you have a writeup?
Originally posted by Stephen Max
What I like about his (s7xr's) setup is that the type of intercooler he uses keeps the intake air away from the hot engine and exhaust manifold. Every other setup I've seen routes the cool air coming from the intercooler back over the front exhaust manifold, heating it back up a little. But the 180 degree turn the air has to make in the intercooler may produce a larger pressure drop than the straight through designs.
But that is about the ONLY thing I like about it and everything else is AFU
You can also look at flow charts for specific intercooler cores. I don't know what everyone else is using, but according to Griffin, my intercooler is 90% efficient at 600cfm, which is almost right on with what i'm running right now. 14psi puts me at about 570cfm.
litch
123
Jan 4, 2024 07:01 PM
Unclejunebug
Apr 2, 2016 05:42 AM
