when do you see peak boost?
Old Jul 10, 2003 | 09:45 AM
ToYLeT902's Avatar
JET Speed Lab
for a 5spd, lets say your supposed to be pushing out 10psi, when do you actually see your gauge hit 10psi?
Old Jul 10, 2003 | 09:48 AM
Confused's Avatar
Permanent Maxima.org Resident
boost is rpm dependant with the vortech blower... the higher the rpms, the higher the boost... peak s/b at 6500
Old Jul 10, 2003 | 10:31 AM
ToYLeT902's Avatar
JET Speed Lab
i think i need a hob(sp) switch, when my key is on the on position u hear a constant feed of fuel or something from the engine, i think that blue thingy people call FMU's or something
where do u buy one?
Old Jul 10, 2003 | 10:42 AM
190hpKiLLA's Avatar
Granny Driven
Old Jul 10, 2003 | 11:24 AM
[maxi-overdose]'s Avatar
you might not see 10psi as they claimed on their pulley. for 13psi pulley, I have only seen 11psi the most so far.
hobb switch threads:
http://forums.maxima.org/showthread....obb+AND+switch
and yes! the blue disk is called FMU (fuel management unit) since you have a 3.125 pulley...make sure you have a 8:1 FMU.
Old Jul 10, 2003 | 11:42 AM
PCGuRu2K's Avatar
Re: when do you see peak boost?
Goto OP with me this weekend and redline each gear with me. You'll see peek boost then
Old Jul 10, 2003 | 01:07 PM
Chunger's Avatar
My other car is a Hybrid
...my key is on the on position u hear a constant feed of fuel or something from the engine...
where do u buy one?
Someone didn't hook up the relay properly to the OEM fuel pump signal so your inline pump is running fulltime in the IGN position.
Old Jul 11, 2003 | 10:23 AM
ToYLeT902's Avatar
JET Speed Lab
ok, i read all those threads, so short and simple is.. i dont need a hobb switch cause it'll create lag, thats why everyone disconnected theres?
Old Jul 11, 2003 | 10:56 AM
Chunger's Avatar
Yes, keep it running fulltime.
The issue of the pump running when the engine is not is more important. If you leave your key on the ign to listen to the radio, it may overheat your inline pump because it should turn off if the engine is not started within 3 seconds.
Old Jul 11, 2003 | 11:50 AM
so true....I always listen to the pump and make sure it is off everytime that I turn off my car.
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
aw11power
Oct 10, 2021 04:57 AM
MichMaxFan
Sep 30, 2015 09:18 AM
