whats the difference between Stillen POP and JWT POP
aren't they identical? (minus the element..one is original k&n the other is generic)
they should produce the same gain right?
wondering because some people said they produce diff gain...
please let me know
thanks
please let me know
thanks
please let me know
thanks
please let me know
thanks
price.
Dan
The people who claim more performance gain from the Stillen Hi-Flo are they people that paid waaaay too much for the same product. True they got a carb certified intake. But performance wise.. they got nothing special.
ZuM
ZuM
ZuM
ZuM
Anyone try the MaxxFMIS????
Anyone this CAI set-up?? Looks to be pretty damn goog, but a bit pricey. Check it out at http://www.maxxfmis.com/index.html
Hey cloud... how well does the Max Rev CAI work? Any info would be great! Thanks.
Re: Anyone try the MaxxFMIS????
Because I had the Stillen unit prior to the Max-Rev CAI it was easy to compare. I installed the Stillen unit first on a trip to the west coast. In the cool dense air at sea level along the beaches of S.Ca. it provided more power than the stock air intake and definitely was louder. After returning to the Phoenix area where I live I discovered that the car wasn't as quick as when the stock air box was on it. In retrospect it should have occured to me that this was to be expected. I've never put a temp guage under the hood but I can tell you that running down to Nogales at 90~100 mph in 110 degree weather with the A/C turned up full tilt that my motor is putting out some serious heat. Pumping that underhood air into the motor is not going to give big, or any, power gains. I wrote of the cost of the Stillen unit to experience, kicked myself in the behind and put in the CAI. If you live in Alaska you might prefer an underhood unit.
Another intake option / Stillen vs. JWT
One thing I have done to my car is take out the Stillen intake kit and put on the stock air box with OEM air filter... Except I left off the restrictive plastic intake pieces that run from the bottom of the air box up to the top of the radiator and also to below the battery.
I notice that feels just about as good if not a little better from idle to 5000RPM as compared to Stillen intake. From 5000-7000 RPM, I guess the Stillen intake runs a little stronger.
What I like about the stock air box (minus restrictive add-on pieces) is that I don't have a torque drop-out (maybe about 10-15%) between 2500-3300 RPM like I frequently noticed with the Stillen K&N intake. The throttle response in this range feels better too with the OEM air box.
At first I thought that having the air box fully opened at the bottom might draw in excessively hot air... But then I figured the Stillen K&N unit is out in the open too for all the hot engine air.
If anybody out there would like to try removing these "restrictor pieces" from their air box, I'd be interested in hearing how it worked out. At least it is a free modification. Thanks...
95 GXE automatic
Ground Control / Stillen FSTB, RSTB, RSB /
95 GXE automatic
t6378tp
Sep 29, 2018 04:27 PM
Stagnet04
Sep 14, 2015 11:28 PM
