Help - High Pitched Noise Coming from Engine
Old Jul 14, 2003 | 08:21 PM
bantae's Avatar
Guys,
I need some help. My wife just told me about a noise her Maxima is making. It is a high pitched noise coming from the right side of the engine (left side if you are facing the engine from the front). The noise is only at idle. If I apply the throttle even the least amount it goes away until it gets back to idle. It does go away on it own also. If I let it sit for about 1 min the fan will kick on and after it runs for about 15-20 seconds the fan kicks off and the noise goes away for a few minutes.
A little about the car
1996 SE Automatic
60K miles
No Mods (unless shaving counts)
I have only had the car for the last 1,000 miles so I am unsure of its exact maintenance history but everything seems to be in tip top condition, and well maintained.
Old Jul 14, 2003 | 08:33 PM
mrblond's Avatar
Re: Help - High Pitched Noise Coming from Engine
I had a similar noise in the same area got it checked out by dealer ended up being the alternator which was under recall.
Old Jul 14, 2003 | 08:57 PM
bantae's Avatar
From what I found that recall was only for the 97-98's.
Old Jul 15, 2003 | 06:55 AM
bantae's Avatar
Any other ideas?
Old Jul 15, 2003 | 02:20 PM
95Max's Avatar
I also had the same noise. Could not fiqure it out. The car would make on the noise on and off. I had to replace the alternator and now went away.
Hondarydr
Dec 30, 2024 06:15 PM
Starrider
Sep 17, 2015 07:26 AM
bc992164
Aug 26, 2015 12:19 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
