Car doesn't crank in hot weather (*sometimes)
Old Aug 19, 2015 | 01:10 PM
bc992164's Avatar
When it's really hot out 95+
Sometimes I walk to the car turn the key and nothing.
All lights come on and beep occurs, but the engine doesn't even attempt to do anything. No noise, clicks...
If you wait for a few mins, sometimes it starts right up.
We have had this issue for a few years...
Any idea what could be causing this?
I had a friend about 5 years ago put on a Cold Air Intake.
He left what I believe is the Air Temperature Sensor Disengaged.
Does anyone know what could be causing this?
Old Aug 19, 2015 | 03:32 PM
DennisMik's Avatar
My first guess would be to check out the ignition switch. It is screwed on to the back end of the ignition key cylinder and is a trouble spot for these cars.
Old Aug 19, 2015 | 09:22 PM
Maxima 97 SE's Avatar
Get the intake air temperature sensor back in there because its plays a key role in air fule ration and starting up. Just plug it back in and put it somewhere it will get some air.
Old Aug 20, 2015 | 03:58 AM
dwapenyi's Avatar
I think that either your battery is dying or your starter is about to go.
Old Aug 20, 2015 | 04:45 AM
Turbobink's Avatar
... agreed.
You need to do some poking and prodding with a multimeter.
Old Aug 20, 2015 | 08:20 AM
njmaxseltd's Avatar
Ignition switch
Starter
Relay
Battery
Old Aug 20, 2015 | 08:59 PM
Junebug1701's Avatar
How about the neutral safety (inhibitor) switch? Shift from Park to Neutral and then try starting it. My Altima has this same problem.
Old Aug 21, 2015 | 01:50 PM
nissan99's Avatar
Maybe your crank sensor flaking out when hot
Old Aug 21, 2015 | 03:00 PM
DennisMik's Avatar
Not the problem at all. The op says the engine doesn't even crank over.
Old Aug 26, 2015 | 12:19 PM
DBear's Avatar
And take a look at this thread: https://maxima.org/forums/4th-genera...ml#post8875419
Smiley101
Aug 1, 2024 08:02 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
acw
Aug 13, 2015 12:50 AM
