SC CAI question
Old Jul 18, 2003 | 08:18 PM
iansw's Avatar
SC CAI question
I read the CAI how-to on maximadriver.com and have a question.
Nowhere in the instructions does it say to remove the windshield washer resiviour....
Do I need to?
Old Jul 18, 2003 | 08:32 PM
Confused's Avatar
Permanent Maxima.org Resident
iirc, cheston had his removed already (cf hood)
Old Jul 18, 2003 | 08:39 PM
iansw's Avatar
OK - then I guess I do need to.
That kind of sucks....the CAI I have now doesn't require that.
Oh well. This is sturdier than my current setup.
Old Jul 19, 2003 | 08:49 AM
Stephen Max's Avatar
Re: SC CAI question
Do I need to?
Yes. Around here where it doesn't rain all that much it's not much of a problem not having a windshield washer. I imagine up in the NW you would need it quite a bit. You could try relocating it to the open area under the battery tray, now that you've freed up all that space with the manual tranny.
Old Jul 19, 2003 | 11:36 AM
Craig Mack's Avatar
All YOUR grammer belong to me
Mine was relocated to the right side of the engine bay. It was stuck in the hole that my N/A CAI pipe used to sit in.
Here is an old pic. Look at the bottom left hand of the pic and you can see it there nudged into the old cai hole:
It rains everyday almost here in Florida so it's needed once in a while.
Old Jul 21, 2003 | 05:58 AM
That's a great idea, Craig. And I just happen to have one of those holes ...
Old Jul 22, 2003 | 04:39 PM
LatinMax's Avatar
I have a write-up that keeps the washer bottle in the normal place. Just clicky on my sig and goto page 3
Old Jul 22, 2003 | 10:12 PM
iansw's Avatar
Uh....nothing in your sig has a "Page 3"
The first link only goes to a picture
The 2nd goes to DNE
The 3rd goes to VQ Power, which is 1 page.
Old Jul 23, 2003 | 05:04 AM
Confused's Avatar
look at page two and scroll down
Old Jul 23, 2003 | 05:32 PM
LatinMax's Avatar
The 2nd goes to DNE
Sorry I must of had a brain fart. Hit my homepage and it will be on page 2 not 3.....Sorry.
Just click on my homepage
Old Jul 24, 2003 | 11:42 AM
ereet's Avatar
http://members.rogers.com/punkface/sc9.jpg
http://members.rogers.com/punkface/sc6.jpg
You will need to remove the stock one. If you're feeling inventive you can buy a smaller one and stick it in there like me. I can get the part #'s if you require, PM me if interested.
Old Jul 24, 2003 | 12:25 PM
iansw's Avatar
Yeah - that's pretty much my setup now. I want something steel and more permanent.
What I have now is falling apart after about a year.
I've got a lot of space after the 5spd conversion - I guess I'll just find a place to put the resiviour.
If not - it rains in Seattle enough that my windshield is pretty much always clean anyway.
IanS
Old Jul 26, 2003 | 09:29 PM
iansw's Avatar
Well - I installed it today.
I used Maximadriver.com's Stahl header pipe and cut it to length.
Unfortunatley, I worked on the car at my friend's house and forgot to bring my Dremel. I already have a hole, but the bottom of it was not cut enough to allow the steel piping to seat properly.
So I got a little inventive and used the rubber accordian section of my old rubber CAI and cut it to fit over the steel piping and the SC on the other end and then tightened it down. Now I can bend my SC CAI pipe whichever direction I want.
And best of all, the Windshield Washer resiviour didn't need to be moved!
No better performance than the all-rubber CAI, but it certainly looks a heck of alot cleaner!
I'll take pics tomorrow or something.
IanS
Old Aug 6, 2003 | 11:53 AM
BlackCat's Avatar
RIP '98 Maxima SE
Instead of getting the Stahl pipe can I get the equivalent from the plumbing dept of Home Depot? I remember seeing a posting somewhere about that.
Ian, are you using the same H&R filter as in Cheston's write-up? I have that but I don't have all of the pieces yet.
Old Aug 6, 2003 | 11:55 AM
iansw's Avatar
I used the K&N that I already had with my old CAI. I just used a 3 1/2" silicone coupling and clamped it on to make it fit.
Old Aug 6, 2003 | 08:49 PM
WizzaMax's Avatar
I have a 3 inch mandrel bent tube for a SC CAI if you wan tto buy it I can get it out to you...it is the same as jdmmax' CAI
Old Aug 7, 2003 | 06:32 PM
MardiGrasMax's Avatar
You want to check the CFM flow of the filter you are using. @11psi you need ~410cfm of flow. Call K&N they can give you the info you need based on the measurments of the filter you have. If its too small they can tell you what you need.
Old Aug 8, 2003 | 06:41 AM
Only 410 cfm at 11 psi? How do you figure?
Old Aug 8, 2003 | 06:52 AM
www.smokemup.com
Old Aug 8, 2003 | 07:25 AM
www.smokemup.com
Great site! I'm still not sure how you got 411 cfm, though. Seems too low.
Old Aug 8, 2003 | 09:47 AM
Craig Mack's Avatar
Don't you guys think 3" is too small?? My piping is mandrel bent, and is like 4" wide. I am using a huge k&n filter, a little bigger then the one that comes with the PR CAI kits.
Old Aug 8, 2003 | 10:21 AM
ejj's Avatar
ejj
The intake on the SC is 3", so as long as you match that it will flow plenty. You're 4" setup would bottleneck at the SC.
Unclejunebug
Apr 2, 2016 05:42 AM
Sep 27, 2015 08:37 AM
Socalstillen
Sep 26, 2015 12:01 PM
