Intermittent misfire at idle
Old Jul 22, 2003 | 02:12 PM
kpic's Avatar
I have a 93 Maxima GXE , I am getting an intermittent misfire at idle. The engine starts fine and does not misfire at speed at all, at idle it may idle fine and then it will stumble a bit just lowering the rpms somewhat but not enough to stall. It is very intermittent , I can also hear a "pop" sound - a misfire - through the muffler , again not constant.
The plugs, pcv, fuel filter, air filter were recently replaced (before the problem) and I just replaced these today: disty cap, plug wires & rotor. Any ideas?
Old Jul 23, 2003 | 01:46 PM
kpic's Avatar
ttt
Old Jul 23, 2003 | 02:55 PM
Psychosis's Avatar
I'd check the connectors to the injectors from the harness, try wiggleing them and see if it gets worse/better. If thats the cause(was on mine) clean the contacts with electrical contact cleaner.. Hope this helps.
Old Jul 24, 2003 | 08:13 AM
DARHAW-MAX's Avatar
Do a check for vacumn leaks. If any of your vacumn hoses are dry and brittle, replace them. Sometimes, a lot of bad idling can be attributed to worn and deterorated vacumn hoses.
jmlee44
Oct 2, 2022 02:13 PM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
