FMU Question
FMU Question
I have a weapon-r FPR and i know that would have been fine for nitrous, but should i get a FMU for my turbo or can i still use the fpr? Or both?
No it doesnt. Thanks for the info. What do you recommend? Cartech or Vortech? Do i need a different one since it is a turbo or will the ones that come with superchargers work?
I would look into the Cartech unit. One unit can adjust base FP, wot FP and the how fast the FP rises per lb boost. Otherwise when you upgrade to a Walbro etc.. you will need one fpr unit for base/wot and another for boost referenced rising rate FP.
Can you take some honest feedback? I've read some of your posts and I know you want to boost. Asking questions here on .org is fine. But .org is not really the BEST source of info. The net in general is. Based on your question here and others I've seen, take a step back and do a massive research run on the net first. I don't know if you are close to starting your project, but I would delay it if you are. It doesn't get any easier from here.
Hell it's not like I'm some pro either.
Originally posted by 96BLUMAX
So maybe ill have the weaponr do base and the cartech do the boost fp.
Yeah it is adjustable. Not very complex of a unit though. Just an input and an output with a threaded top that turns to raise or lower. It also has one vacumn connection that i guess we have determined is for raising the fp at WOT.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
