FMU Question
Old Jul 23, 2003 | 11:21 AM
96BLUMAX's Avatar
FMU Question
I have a weapon-r FPR and i know that would have been fine for nitrous, but should i get a FMU for my turbo or can i still use the fpr? Or both?
Old Jul 23, 2003 | 11:27 AM
Jeff92se's Avatar
I'm needing a caw
Does it feature a boost referenced adjustable rising rate? If not, then you need a different unit.
Old Jul 23, 2003 | 11:43 AM
96BLUMAX's Avatar
No it doesnt. Thanks for the info. What do you recommend? Cartech or Vortech? Do i need a different one since it is a turbo or will the ones that come with superchargers work?
Old Jul 23, 2003 | 03:00 PM
96BLUMAX's Avatar
Now here is one last question. My fpr has a vacumn connection. Does that cause it to rise? Or do the ones your talking about have two connections?
Old Jul 23, 2003 | 03:19 PM
Jeff92se's Avatar
I'm needing a caw
I would look into the Cartech unit. One unit can adjust base FP, wot FP and the how fast the FP rises per lb boost. Otherwise when you upgrade to a Walbro etc.. you will need one fpr unit for base/wot and another for boost referenced rising rate FP.
Can you take some honest feedback? I've read some of your posts and I know you want to boost. Asking questions here on .org is fine. But .org is not really the BEST source of info. The net in general is. Based on your question here and others I've seen, take a step back and do a massive research run on the net first. I don't know if you are close to starting your project, but I would delay it if you are. It doesn't get any easier from here.
Hell it's not like I'm some pro either.
Old Jul 24, 2003 | 06:53 AM
96BLUMAX's Avatar
True but i the reason why i ask all these dumb questions is because i am second guessing everything just in case i learned something wrong.
Old Jul 24, 2003 | 08:06 AM
[maxi-overdose]'s Avatar
I thought the cartech does not adjust base FP. Vortech super FMU does....but it is quite expensive.
Old Jul 24, 2003 | 08:16 AM
96BLUMAX's Avatar
So maybe ill have the weaponr do base and the cartech do the boost fp.
Old Jul 24, 2003 | 08:19 AM
sounds good...is weapon R FPR adjustable? if so, you can lower your base FP a little so you will have more room to raise your fuel pressure.
Old Jul 24, 2003 | 08:23 AM
96BLUMAX's Avatar
Yeah it is adjustable. Not very complex of a unit though. Just an input and an output with a threaded top that turns to raise or lower. It also has one vacumn connection that i guess we have determined is for raising the fp at WOT.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
