Is my clutch dead??
Old Jul 24, 2003 | 08:41 AM
negreenfield's Avatar
Is my clutch dead??
I've had a clutch go out on an old accord but it started slipping before hand, so it was quite obvious. On my maxima my clutch felt "funny" yesterday, it's usually pretty stiff but didn't have the same feedback it normally does, and the gears were rather difficult to engage. Today my car will not shift into any gear, except second. Is this a clutch or a tranny?
-TIA
Old Jul 24, 2003 | 08:50 AM
Jeff92se's Avatar
I'm needing a caw
Check the clutch MS for proper fluid level, check the lines for leaks and try rebleeding the slave cylinder. Check stickes for these procedures
Old Jul 24, 2003 | 08:51 AM
thanks for the quick reply, god i hope it's not the tranny
Old Jul 24, 2003 | 09:47 AM
maxi-freak's Avatar
If it's the clutch you can get a few more miles out of it by making a small adjustment on the clutch master cylinder plunger rod. It's like a 8mm nut at the floor board to loosen, then you can lengthen the rod slightly..then tighten it back.
Old Jul 24, 2003 | 03:13 PM
vwink182's Avatar
Like 2 weeks ago I had my clutch go out all at once, even more sudden than yours. It sounds like from what you described that it is the clutch. it cost me 450 for clutch and install, let me know what you spend if it is the clutch...i can't help but feel I paid too much
Old Jul 24, 2003 | 05:35 PM
Paul89SE's Avatar
$450 for clutch and install? I paid $850 but I needed a slave cylinder, pressure plate and flywheel machined. It was replaced the year before at the dealer. I took it to an HONEST transmission shop, if there is such a thing.
Old Jul 24, 2003 | 07:21 PM
Well, fluid level was low but that made no difference when I added fluid, the clutch just feels very different than it used to, just in the course of one day, I'll try out a few of the above described things and hopefully I won't have to replace the whole thing...
Old Jul 26, 2003 | 02:12 PM
Agamemnon's Avatar
Well, it's possible that your clutch master cylinder is broken (leaking etc.) Mine just got replaced not too long ago. Clutch pedal went soft, and it was hard to shift gear, as the clutch won't release fully. If that's what happened, then you might have the same problem.
Old Jul 26, 2003 | 02:34 PM
N34JZ's Avatar
Needs non-Maxima Friends
mabey its the clutch pedal bracket, dont get me started on that thing
Old Jul 26, 2003 | 06:07 PM
NismoDrew91SE's Avatar
$450 is too expensive, heh. a few yrs ago before i got my hands on the car, my dad had the original clutch go out, his mistake was going to the dealership. was a $1200 + dollar job, with the master and slave cylinders. nissan also jipped us by putting in a crappy key value clutch, instead of a tru nissan oem. i've never had a clutch go on me, what would a slipping clutch feel like. i notice i've been having some problems with this one, like hesitation while disengaging among with it being a little jerky
Old Jul 26, 2003 | 08:03 PM
subs1000w's Avatar
if the fluid level gets to low air will get in the lines hence the need for bleeding the clutch which will get the air out and all fluid in and it should work it sounds like you have air in your line
Old Jul 27, 2003 | 10:37 PM
sounds like what mine was doing, wasn't a full clutch job, came out to $200+, feels like a brand new clutch
thanks for all the replies!
Old Jul 27, 2003 | 10:39 PM
Agamemnon's Avatar
Er, my trusty mechanic (who sold me the car) did it for $90... parts and labor! Parts might not be Nissan original though. But hey, it fixes the problem!
Old Jul 27, 2003 | 10:46 PM
Argh! I wish you hadn't told me that!
just happy to have my car back to normal.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
markevans999
Sep 10, 2015 04:29 PM
