bad tranny or getting ripped off?
Old Sep 23, 2015 | 11:04 AM
carlosvq30's Avatar
Hi i need advice from someone
i have a 2000 maxima just bought its a 5speed.
i was driving one day and anytime the clutch was engange it would make a noise
only time it wouldnt is if i had the clutch pedal to the floor
i thought it was the t/0 bearing so i ordered clutch.
fyi- it was leaking trans fluid for a few months cause of the shaft seal, right before the t/o bearing went the gears would grind a bit going from 2-3 or 3-4 i would have to shift at low rpm or double clutch.. car sat for two months after this and now i towed it to the shop and they said i need a new trans and its 1800 for replace and labor ..
advice??
thank you
Old Sep 23, 2015 | 02:28 PM
carlosvq30's Avatar
Also the car wouldnt go into amy gear
Old Sep 24, 2015 | 03:53 AM
4thGenTuner's Avatar
advice??
thank you
So, basically if you push the clutch in and the noise goes away your input shaft bearing is on its way out. If its the other way around, I.E. clutch out and it makes noise its the throw out bearing.
Since it wont go into gear either your clutch is toast or the gearbox is toast.
My last trans swap cost me less then $1400. That included a J/Y trans with 89,000 miles, all new seals, new lightweight flywheel, ACT clutch kit, & gear oil. The clutch & flywheel were the bulk of the cost at like 800ish, 300 for the trans, & the last 300 on seals gear oil & other stuff. I also installed a stainless braided clutch line.
I did all the work myself though.
If 1800 includes installing a new clutch kit & seals then its not a bad price I guess.
You could do it yourself & save some money.
Old Sep 24, 2015 | 01:10 PM
carlosvq30's Avatar
Originally Posted by 4thGenTuner
So, basically if you push the clutch in and the noise goes away your input shaft bearing is on its way out. If its the other way around, I.E. clutch in and it makes noise its the throw out bearing. Since it wont go into gear either your clutch is toast or the gearbox is toast. My last trans swap cost me less then $1400. That included a J/Y trans with 89,000 miles, all new seals, new lightweight flywheel, ACT clutch kit, & gear oil. The clutch & flywheel were the bulk of the cost at like 800ish, 300 for the trans, & the last 300 on seals gear oil & other stuff. I also installed a stainless braided clutch line. I did all the work myself though. If 1800 includes installing a new clutch kit & seals then its not a bad price I guess. You could do it yourself & save some money.
not sure what area ur in but where u buy trans ? Im looking for one now and junkyards have them for about 1000 and im not doijg the work cause i dont have the time or tools :/
Old Sep 26, 2015 | 09:44 AM
Try Car-part.com.
Other than that the classifieds here or junk yards close to your area.
chisam14
Nov 6, 2018 08:56 PM
fx4five
Oct 1, 2015 04:58 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
