aux. fuel pump question?
ok i think i might have found my problem, my aux. pump is not kicking on when i turn the key. when i do turn the key i feel a small vibration when touching the pump but it only last about a sec. if the aux. pump is not hooked up right will it cause the problems that i am having(stalling,bad idle after reving,won't rev past 3500rpms)? god i hope so,should i beable to feel the pump when its on? what about hearing it? (i currently don't hear anything coming from the fuel pump) i would like to thank you guys who helped me so far as i'am still new to the whole sc thing
Re: aux. fuel pump question?
There is a modification you can do to the Hobbs switch so that the aux fuel pump is always on. I'm not familiar with the modification since I use an upgraded in-tank fuel pump and never installed the Hobbs switch and aux fuel pump. Do a search on Hobbs and you'll eventually find a write-up.
