supercharger intercooler?
if I recall a few months ago soeone was talking about having an FMIC kit for the SC fab'd for the Maimxa. also I think Criag Mack was talking about a possible aftercooler kit(AWIC) as well a few days ago for his 4th gen.
Originally posted by PmpLuxCEO
what about for 4th gen people? Just wanna know the cost involved and I'm assuming that custom piping will have to be done.
I decided to scrape my FMIC project and do a AWIC... Looks like I'll save my Spearco IC for my future MKIII. I'm not in a big rush as I haven't seen any detonation even with the 3.12".
I30Krab has a AWIC for his S/C.
I'll tell you what ever I can just ask.
It's a custom made intercooler through and through, not somthing you can buy on the street. Piping runs right out of the pressure side of the blower down by the radiater into the top side of the intercooler, out of the intercooler under the frame back right up toward the t.b. The only pics I have are on my wedsite, just use the arrows and double click the pics to blow them up.
Thanks for the info. Very interesting pics.
How much pressure drop are you getting through the IC and piping? Any temperature drop measurements?
and what are you dynoing with that intercooler?,
I have a Nitrous kit but if an intercooler is a better way to go then Ill go intercooler route and 2.87 pulley and spray the intercooler some more vice inside the throttle body. Whats your opinion on this?
Never measured the temp, lose slightly more than 1 psi now. That lose in pressure is more than made up for in the tq.
The pully on there now is the 2.87 now.
I woun't spray the intercooler I don't see any real advantage to doing it, the air just don't get that hot.
I'm sure my never ending search for more low end power without happy gas will stay that way...
Too many people caught up in this turbo stuff. It still dont' hit that low...even my 5.0 v8 dont' have much power at 1k rpms...
But really what people seem to want is a whole new feeling car. Reality is you can only go so far with so much...With that said it's worth it. The engine runs so much cooler, smoother and flat better. Looking at around 15 hp, 20 ft lbs of tq, 1 psi of boost and a much better feel. The one thing I can't dyno is the feel. It's as fast if not faster than my M5....I don't know what more to say. That 800 bucks ain't bad compared to what the mods cost for the m5 either...I'm talking 8000 for headers...It cost to play...plain and simple.
Originally posted by Craig Mack
That's what I dont get - How will an intercooler/aftercooler justify it's costs with the nominal (compared to turbos) power gains? The Supercharger Compressor doesn't heat up nearly as much, so why pay $800 for a 12hp/12tq increase across the power band? Maybe if we saw 30hp/30tq (not peak) it would be well worth it.
when you increase your boost to a certain point, you will have more things to worry about. for every 1psi of boost, it will add 10 degree F of temperature to your intake air.and if you are boosting under a 90 degree weather...you will feel the diff.
Originally posted by [maxi-overdose]
to prevent detonation, craigy....
I know humidity kills power, so Floridians and other hot places could see substantial gains in that regard.
[maxi], are you saying that the more boost your pushing, the more of an effect the intercooler will have? Some think that intake heat is not psi dependent.
30tq from 2000rpm-5000rpm or bust.
Intercoolers are more effective with more boost because the higher intake temperatures concomitant with higher boost pressure result in a larger temperature differential between the charge air and ambient air, and the temperature differential is the driving force for any kind of heat transfer. That's also why intercoolers are more efficient on cold days, and also why cooling the intercooler with a spray is so effective. It's also why you can get better than 100% efficiency with an air to water intercooler packed with ice.
AWIC
i was the first to have an awic. check my webpage for pics. it was not the cleanest set up since i was tying to make it to a race.
http://maxima.cardomain.com/id/sleepin99
if you have questions, post them. later.
Ferhan
Ferhan
Re: AWIC
Ferhan
Ferhan
Also, I noticed you have a 3" exhaust. How do you like it? Did you notice any loss of low end power or partial throttle performance with it?
exhaust?
did not notice any loss at low end. i was running low 13 on stock tires coming out of the hole at the track. gas was just over half throttle until i passed 40 mph at the track. had no traction. dynos were just under 350 on less than 7 to 8 psi of boost.
don't really know all the specs on the set up but it works great. once the car is running again, i can post intake temp. normal cost on my set up is 1800 to 2000, includes fab and install. my system is very similar to a cyclone or typhon set up.
last thing, mine may be for sale soon. if i go to a turbo on my built motor. later.
Ferhan
Ferhan
craig, are you going to be making a kit for the rest of us to purchase? OR are you just talkin about for yourself only? LOL! the 2K spent on that custom one is kinda steep for me.
If he does make one (aftercooler) for my car, then he will mass produce it for you guys too.
t6378tp
Sep 29, 2018 04:27 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
