Oil Return Lines for Turbos
Old Aug 1, 2003 | 08:14 PM
Ramius83
What exact hose/line should be used when doing an oil return line for a turbocharger? Where should it go on the engine? And, lastly, where can I get one? Thanks all.
Old Aug 1, 2003 | 08:55 PM
thebigsadler's Avatar
it should be tapped on the line coming off the oil pan, the main line i have been told.. what that means exactly i am unsure, but just trying to shed what little knownledge I have.
Old Aug 1, 2003 | 11:00 PM
Ramius83
Well, I think you are a little mixed up Jason. You tap that line going into the oil pan for the oil feed line. You tap that right where the oil pressure sender switch is. I need to know what to do with the oil return line. Included with this kit was a 1 foot long section of regular high pressure hose that was secured to a fitting that bolted to the turbo. The other side then feeds into the upper valve cover. I just need to know if this is ok, or if there is a better location that I can do relatively cheap. Thanks again Jason.....
Old Aug 1, 2003 | 11:03 PM
sx7r's Avatar
the oil return line should be -10AN if using stainless steel lines and aluminum fittings. if you're using rubber hose and barbed fittings, get something that's at least 5/8" ID. The ideal place to return the oil is in the upper oil pan. www.summitracing.com has SS lines and Earl's fittings. your local auto parts store has high temp rubber lines if you choose to go that route.
Old Aug 1, 2003 | 11:41 PM
Ramius83
I have the high temp rubber hose already. But the PFI kit has it routing to the valve cover. Is this ok to do or should I just do the upper oil pan? Does anyone have pictures of the line routing to the upper oil pan. Thanks for the help Thomas.
Old Aug 2, 2003 | 05:54 AM
Bags's Avatar
VG Ridah's Biatch Hoe
Eric I can come by if needed tomorrow
Old Aug 4, 2003 | 06:10 AM
Julio's Avatar
[QUOTE]Originally posted by bags533
[B]
What is that a picture of exactly, dont have a VQ motor to compare with. (valve cover or oil pan, possibly your oil press. sender ?)
Old Aug 4, 2003 | 10:40 AM
Bags's Avatar
[QUOTE]Originally posted by Julio
Your looking at the front part of my oil pan. The pipe that comes down and connects to another pipe is my y-pipe
hope that helps
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
