Ghost Code
Ghost Code
OK now. I've been looking closely @ the threads regarding check engine codes and have noticed the term "Ghost Code" what is that? For example, on my 95 GXE. I pulled the code 0304 (K-Sensor) then it puked the code 0407 which allegedly means Crankshaft Position Sensor is bad. So which if any of those is a "Ghost Code". P.S. My check engine light came on after I replaced the starter. Could that procedure have affected those sensors????
if in dout test with a Ohm/volt meter before replacing. A few months ago my speedometer went bad and it was giving me a bad speed sensor code. I replaced the speed sensor and it didnt fix the problem...this is a prefect example why we should always test the component before replacing it.
Re: Ghost Code
After getting those codes, I reset the ECU and the check engine light has not come back on since then (8/1). I don't get it.
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
