Who is using an oil restrictor?
Old Aug 4, 2003 | 10:43 PM
Lonely Driver's Avatar
Is it better to use one for the oil feed to the turbo? I read on the sr forums - "Unrestricted oil flow will blow through the turbo oil seals and coat the insides of your intercooler pipes. A turbo only needs like 10psi of oil pressure at the most." Is this true? What's the stock oil pressure on our engine?
Old Aug 5, 2003 | 07:59 AM
Stephen Max's Avatar
Re: Who is using an oil restrictor?
I see about 50 psi cruising, anywhere between 70 to 100 psi at redline (depending on how heat-soaked the engine is).
Old Aug 6, 2003 | 10:07 AM
turbo97SE's Avatar
There are seals (I always forget what they are called) on the turbo you have that prevent leakage. It is even possible to run oil through it horizontally or even slightly upwards with that kind of pressure and it won't leak. It really depends on the type of turbo you use. Some diesel turbos do not have these seals and certain brands such as TEC do not have these seals as standard.
If you really want to put something in, you might want to consider a small filter. I have heard that Turboetics has them now but I have never seen one.
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
