Engine Swap.....
Old Aug 8, 2003 | 07:53 AM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Engine Swap.....
This could be Stupid Question, I couldn't do a search, it didn't work. I like to know if i can swap out my engine with 2000 maxima. Since it has more Horsepower then the 99 maxima. If that is possible do i need a new ECU or anything else????
Old Aug 8, 2003 | 08:00 AM
dss42's Avatar
will cost too much money it is not worth it. Just get Supercharger or turbo.
Old Aug 8, 2003 | 08:10 AM
clee130's Avatar
The extra hp do not come from the engine.
Old Aug 8, 2003 | 08:33 AM
ivelweyz
Hey, I'm not stupid...
Old Aug 8, 2003 | 08:35 AM
brizsblackmax's Avatar
um a 200 motor isnt worth the gain, do a 2k3 swap with 265hp
Old Aug 8, 2003 | 12:42 PM
nismology's Avatar
The extra power comes from an improved intake manifold and exhaust system as well as a hotter camshaft profile. Although the exhaust can always be swapped out for an aftermarket one, the MEVI isn't nearly as efficient as the DE-K's VI and replacing cams is too dam expensive. Oh yea, it wouldn't be worth it.
Old Aug 8, 2003 | 12:56 PM
ummm 3.5 helllllooooooo?????
Old Aug 8, 2003 | 01:02 PM
maxS
i swapped the eng in my wfs 96 max which had like a mill miles on it with a 2000. But i used 96 intake, ecm, harness etc.
Old Aug 8, 2003 | 08:21 PM
CystumMax's Avatar
Thanks everyone for the info. Can I swap the engine with 2k3?
Old Aug 8, 2003 | 09:16 PM
ivelweyz
ummm 3.5 hell no?????
were you born yesterday? There is a reason why no one suggested it besides you...
Old Aug 8, 2003 | 09:17 PM
ivelweyz
Um BS. What hood did you use? How did you get it to fit? Did you cut into the firewall???
Old Aug 8, 2003 | 09:25 PM
CystumMax's Avatar
IT was Question Buddy... Did you take your medications????
Old Aug 8, 2003 | 11:08 PM
maxS
everything fits with no problem
Old Aug 9, 2003 | 12:35 AM
The_Bomb's Avatar
I don't know if I would call BS on him... isn't the block the same for 95-01? The only problem is the taller intake manifold, and if he used the manifold off the 96 wouldn't it fit? he only appears to have used the block and put all the other engine components on from the 96. But I could be very wrong... just guessing.
Adam
Old Aug 9, 2003 | 09:49 AM
nismology's Avatar
What the hell would be the point of swapping in a 5G 3.0 in there and using the 4G USIM?? A lot of the extra power comes from the VI. That's taking 2 steps forward and three steps back. I hope you plan on somehow fitting the 5G manifold under that hood or else you just wasted a whole lotta money. Wait. Why am I talking like I believe you??
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
