How to replace a hub...DIY or Shop work only?
Old Aug 8, 2003 | 08:46 AM
cam_honestiam's Avatar
Unfortunately, one of the lug studs on my Max has been stripped in the hub. I had the delightful experience of stripping the stud with the lug nut, popping the lug stud out of its threads, and then trying to reomve the lug nut. It was nearly impossible, but now that it is out, I need a new hub since the threads for the stud are stripped.
I looked into getting a new hub, and I was wondering if anyone knows where to find one cheaper than $115.00 WITHOUT going to a junk yard.
Also, how do I swap out the old hub with the new? Do I need a press of some sort? Can I do that myself, or is it better for a shop? Thanks in advance for ANY pertinent information.
Old Aug 8, 2003 | 09:01 AM
96sleeper's Avatar
if I understand you correctly, you only stripped a stud? You don't have to replace the hub, you just need a new stud. Any parts store will have them, you just knock the old one out, and put the new one in. Throw several washers on there and a lugnut and tighten it down until the stud is fully seated.
Old Aug 8, 2003 | 09:07 AM
No, I guess I didnot explain. The stud is stripped, as well as the hub socket that the stud fits into. Putting a new lug stud in the socket (for lack of a better word) would not work because the way the socket on the hub is (it appears that it was once stripped and fixed with a JB weld), I wouldn't even need to hammer or press the stud in. It goes in and out without much effort. Therefore, I know the hub is damaged.
Old Aug 8, 2003 | 02:20 PM
I tried finding out info witht he search feature, but had no luck... Anyone else have any ideas?
Old Aug 14, 2003 | 05:53 PM
kyllr's Avatar
Dude why dont you want a used one. i needed mine replaced so i called aroung and i got a complete knuckle & hub for 75 bucks. Now my car runs great. no problems at all. Dealer wanted 150.00 just for the wheel hub.
jerrod99_se-l
Aug 27, 2015 08:27 PM
vanebecker
Aug 17, 2015 08:24 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
kirkhilles
Aug 8, 2015 10:53 AM
kenc15
Aug 5, 2015 08:29 AM
