1995-2003 Crank Pulleys UnderDriven and Lightened
Old Aug 8, 2003 | 01:50 PM
JBL85's Avatar
I am having another DMSperformance group buy on the Crank Pulleys. These are now available in Blue, Black and Silver. This is the lightest weight pulley avilable on the market, it beats out UR and RVM.
Price is $120 + shipping Anywhere INSIDE the U.S., if you are in Alaska or Hawaii, contact me before ordering.
If you would like belts, I will need a minimum of 5 people to buy the belts. One is required for the VQ35's and is $25, two are required for the VQ30 and it will cost $40 for both belts.
People can purchase now, no need to wait for a bunch of people to jump in. However, if you do want to wait, after 10 orders I can sell them for $115 + shipping.
To purchase:
Paypal: Send money to Nick@definitivemotorsports.com. Include what you are purchasing (quantity, color) and for what year Maxima you are purchasing.
Credit Card: E-mail me
Checks or money order: check out website to obtain address and send checks out to Definitive Motor Sports. www.dmsperformance.com
Any questions, Email me at Nick@dmsperformance.com
Thank You,
Nick
Old Aug 9, 2003 | 10:23 PM
crazy4maxima's Avatar
3rd gens get no love
Old Aug 10, 2003 | 10:15 AM
96shogunmax's Avatar
Is the oil leak problem fixed?
Old Aug 10, 2003 | 10:54 AM
cerumo's Avatar
can I use the stock belt?
thanks.
Old Aug 10, 2003 | 11:05 AM
JBL85's Avatar
We never had a leak problem with our pulleys, that was RVM. We use a bronze bushing which is more wear resistant than the bushing on the UR pulley.
thanks.
What year Maxima do you have. This pulley is under driven, VQ35 only needs to change one belt, VQ30 needs both changed.
Actually if you want to take yours off, mail it to me, I can copy it and make it out of light weight aluminum. But you would have down time.
Old Aug 10, 2003 | 11:09 AM
Sorry for the confusion. How much do they weight?
Old Aug 10, 2003 | 11:17 AM
JBL85's Avatar
Definitive (old pulleys, the anodizing on the new ones is nice and shiney)
UR
Old Aug 10, 2003 | 05:17 PM
Jason R's Avatar
aka UNCDooD
those the only color pulleys you have?
Old Aug 10, 2003 | 05:18 PM
JBL85's Avatar
Silver, Black and Blue
Old Aug 10, 2003 | 07:43 PM
Who looks at it anyways..haha
What color did you want?
Old Aug 11, 2003 | 03:35 AM
Jason R's Avatar
aka UNCDooD
i want a silver one.
Old Aug 11, 2003 | 02:51 PM
JBL85's Avatar
I have silver as well.
Old Aug 12, 2003 | 10:23 AM
MDr's Avatar
MDr
How hard to install ?
Does it come with install instructions ?
Old Aug 12, 2003 | 01:07 PM
HNDA ETR's Avatar
Still Here... IM me for more..
Just installed my DMS UD Pulley!
Hey Guys,
Just had my Definitive UD Pulley installed last night - No problems!
Installing the UDP took about 20 minutes - Which was faster than it took to change all my spark plugs! Getting the back 3 plugs changed on my 2K took about 45 minutes!
The OEM Crank Pulley came off without a hitch. Here's the steps (for 2K):
1: remove front passenger tire (you'll probably need to jack up the car for this part )
2: remove the inner wheel well shield/plastic piece
3: loosen the belt tensioners - 1 from bottom and 1 from top of engine (must loosen the 'locking' nuts first of course.
4: remove loosened belts
5: un-bolt crank pulley - This is how my guy broke the bolt free - he put a breaker bar onto the crank bolt with the handle resting on the ground and bumped the engine. This loosened the pulley bolt with ease! Remember, just 'Bump' the engine, DON'T crank it. (He's a Nissan Master Tech (with the 'Ring' too!), so I didn't question him on this) then, he removed the crank pulley by grasping in both hands and wiggling it side to side while pulling - popped right off!
6: Remove old oil seal - install new one (my 2K has around 45K miles, but the seal still looked brand new) and make sure it's seated all the way in - we used a rubber hammer to 'tap' it all the way in.
7: Put UDP pulley on - used rubber hammer to seat the pulley all the way. Tighten crank bolt back on.
8: Install 2 new belts - This took a few minutes - Tension them just right and lock them down with the 'locking' nuts (make sure belts are seated properly on all pulleys. You'll probably have to use the breaker bar to turn the crank so the belts seat all the way)
9: Replace wheel well shield/plastic piece
10: Start 'er up!
Car runs great - No engine light or anything! Haven't noticed much difference in performance, but a 4-5 horse gain isn't gonna be too noticible.. Until ALL the mods starting adding up!
FYI - Installed the Denso Iridium spark plugs.
Good luck you guys! Nick, Thanks again for the UDP!
Old Aug 12, 2003 | 02:15 PM
leprosybear's Avatar
how much smaller is this crank compared to the stock one and the unortho one?
Old Aug 13, 2003 | 08:39 AM
Titleistprov21's Avatar
does this come with belts or can you use the stock belts?
Old Aug 13, 2003 | 08:53 AM
HNDA ETR's Avatar
leprosybear: The diameter of the UDP is smaller than the stock one, couldn't tell you how much without actually measuring them, but the biggest difference is the weight. The stock pulley probably weighs 4-5 pounds, whereas the Definitive UDP, as you can see in the pic up top, weighs 1.28 pounds. This means less reciprocating weight for your engine to turn. Given a modest gain of about 2-4 horsepower per pound lost, you're looking at a gain of approx. ~6-12hp.
Titleistprov21: You'll have to use different belts, smaller diameter pulley=smaller belts. I got mine from Nick@definitive, but you can get yours elsewhere if you wanted...
3 days, still no problems!!
Old Aug 13, 2003 | 07:24 PM
I want one, however, i need the belts too. If 5 people don't buy the belts, can I pay a couple more $$ for them. Where do you get the belts from? Also, the website doesn't work for me. Can you please PM me with the address to send the money order. ALso, what is the warranty on the pulley's? Thanks
EDIT: Website works now. My computer was acting weird
-Pat
Old Aug 14, 2003 | 02:27 PM
JBL85's Avatar
hey titeleistprov21, I guess that was your email I just got, address is
23162 La Cadena
Laguna Hills, CA
92653
Old Aug 14, 2003 | 02:31 PM
JBL85's Avatar
Also if any one wants belts, just let me know, you dont have to wait for 5 people to jump in.
Nick
Old Aug 14, 2003 | 03:24 PM
jdmmax's Avatar
i remembered you saying something abouta stock sized aluminum crank pulley do you still have those aailable ???
Old Aug 14, 2003 | 04:42 PM
JBL85's Avatar
You can buy those from UR, I was gonna make it, but they already had it.
-Nick
Old Aug 14, 2003 | 07:47 PM
davidme's Avatar
why are the pulleys so expensive ?
the light'ned set for my Mustang was $50 ...
Old Aug 14, 2003 | 08:01 PM
plurco's Avatar
Because there are millions of mustangs being modded. It's that whole supply and demand thing. Plust this is probably a couple guys and a CNC machine making these, not a multibillion dollar coperation pumpin these things out by the thousands.
Old Aug 14, 2003 | 10:07 PM
JBL85's Avatar
Originally posted by plurco
Plus this is probably a couple guys and a CNC machine making these
Yup, I thought these prices were low though, for the low quantity we make, we are selling them cheaper than UR.
-Nick
Old Aug 14, 2003 | 10:16 PM
HNDA ETR's Avatar
Definitely worth the money!
Old Aug 15, 2003 | 12:12 AM
JBL85's Avatar
^Thank You
Just wanted to let everyone know, I wont be responding to E-mails or posts until next thursday, but this gd is still open.
-Nick
Old Aug 15, 2003 | 01:15 AM
JBL85's Avatar
^picture of a VQ35(OEM) pulley next to our pulley
Old Aug 16, 2003 | 08:10 AM
2K2DEMAX's Avatar
Pele ain't got nothing on me
Yon mean, "definitively" worth the money (Sorry for the pun)
Anyway, I agree. I got one from the previous GD and it was a good experience, both from customer service and merchandise quality perspectives. Install was a cinch. No problems so far.
Old Aug 20, 2003 | 11:21 AM
twllin's Avatar
whats the diff between this and the underdrive pulley?
Old Aug 21, 2003 | 07:52 PM
JBL85's Avatar
The DMS pulley is under driven.
Old Aug 22, 2003 | 09:50 PM
studman's Avatar
I'm attesting to this thread and JBL85's reliability. I've had my pulley installed on my '02 Max for over 10,000 miles with no issues whatsoever. If you have the VQ35 engine, installation instructions are available on my homepage. Just follow the link at the bottom. Pictures are included.
Old Aug 22, 2003 | 10:39 PM
Re: 1995-2003 Crank Pulleys UnderDriven and Lightened
Price is $125 Shipped Anywhere INSIDE the U.S., if you are in Alaska or Hawaii, contact me before ordering.
People can purchase now, no need to wait for a bunch of people to jump in. However, if you do want to wait, after 10 orders I can sell them for $120 Shipped.
To purchase:
Thank You,
Nick
Can I get a price on a silver one and both belts? Also what kind of belts are they?
Old Aug 22, 2003 | 11:19 PM
MrGone's Avatar
Hey Nick,
You would only need the stock crank pulley to make a lightened underdrive pulley?
If so, how much do you think it will cost?
The Cheapest I've found for our VE30DE's is here,
http://www.rpmoutlet.com/aspimp.htm#nissan
Part Number ASP339800
I have an extra stock pulley from my spare motor.
Let me know if you would be interested in doing it.
Old Aug 25, 2003 | 09:40 AM
JBL85's Avatar
I can't beat their price of $100, you are better off getting it there, sorry.
Old Aug 25, 2003 | 09:42 AM
JBL85's Avatar
$165 shipped. They are Bando, I can also get you Advantex belts, but Bando is the same price and better quality belt.
Old Aug 28, 2003 | 05:51 PM
bluA32's Avatar
あおい A32
got mine yesterday. Left you a trader rating.
Old Sep 2, 2003 | 09:17 PM
JBL85's Avatar
thanks did the same
Old Sep 12, 2003 | 11:31 AM
JBL85's Avatar
If anyone else is interested, email me, otherwise the GB is over in a week.
For those who did email me, the offer is open till you get me the payment.
Thanks to those that participated
-nick
Old Sep 12, 2003 | 05:31 PM
bobjohnson's Avatar
Blazin......
Hey any reviews of these on a 4th gen , 95 auto.
Im really intrested in it and about those belts, do u have em in stock or enough people to do this now?
