Fuel injectors???
Old Aug 8, 2003 | 03:19 PM
max80228's Avatar
Fuel injectors???
I have a 95 se 5 speed. I am still having problems with loss of power in general. And my gas milege is horrible also. I have no codes and have checked everything i can think of and find on here. Has anyone tried cleaning the injectors and how do you do it? Ive already tried the 44k and no change in performance. Am i missing something??? Please advise and help.....
Old Aug 8, 2003 | 03:22 PM
max80228's Avatar
Also has anyone tried the service offered a Grease Monkey, Jiffy lube ect to have the system cleaned, including the vacuum lines?
Old Aug 8, 2003 | 05:37 PM
BEJAY1's Avatar
Conecarver
Let's assuming you've replaced the fuel filter, changed plugs, and checked the air filter. Then a fuel system cleaning might be in order. I've used the Motorvac cleanings with good success. You could also try a bottle of fuel sys cleaner before taking it in.\
Old Aug 8, 2003 | 05:42 PM
Jeff92se's Avatar
I'm needing a caw
O2 sensor.
Old Aug 8, 2003 | 07:08 PM
maximomo's Avatar
Re: Fuel injectors???
Get a 32 ounce can of Outlaw fuel system cleaner and Octane booster.
Put 16 oz. in your tank and fill it up. Drive it until 1/2 tank and put the rest in and fill up again.
If you still have power and gas mileage problems then you have an O2 sesnor problem, or bad TPS, or bad Air flow meter ground, or.... one of about 30 other things.
Go to the Beta test site (it's nearly a mirror image of this site but SEARCH IS TURNED ON) and search for power loss or gas mileage posts.
Click the big red letters up top!
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
