Alignment Problems
Old Aug 16, 2003 | 04:18 PM
brizsblackmax's Avatar
Alignment Problems
my alignment shop tells me now that i droped my car with sprints/tokicos he cant correctly align the car because the standard factory specs to alighn to are scrap now... how do you align a lowered 4th gen correctly??
Old Aug 16, 2003 | 04:24 PM
nismos14's Avatar
§è~® f®ÈÄk
uh i disagree u can still use the factory spec, goodyear just did mind today after getting it dropped, no problems
Old Aug 16, 2003 | 05:20 PM
njmaxseltd's Avatar
Re: Alignment Problems
Find another shop that knows what there doing and have them align your car. It should be set to the factory spec. CAmber might run a little heavy in the negative but toe should be set correctly. You can put camber correction bolts in to correct the camber if indeed you run to much into the negative.
matts95max
Apr 23, 2025 10:44 AM
NewMax03
Oct 7, 2015 08:27 AM
06maxima55
Sep 28, 2015 04:29 PM
ivorton23
Sep 26, 2015 09:47 AM
