First time w/ nitrous at the track, fried the clutch...need help!
Old Aug 17, 2003 | 02:27 PM
99Maxima5sp's Avatar
Well i just came back from desoto speedway after running my car. It was my first try with my nitrous setup (50-shot, wet). Well, my first run i ran a 14.5@97, but noticed what i thought to be my tires spinning in every gear. Well, indeed, it turned out to be my clutch slightly slipping. So i run again about 1 hour later, and my clutch never really engaged, it pretty much spun the entire way, leading to only a 14.8@93.
Well, i figured my clutch would still be ok, but i went home anyways. I decided to punch it to see if the clutch was still slipping, and bam, completely slipped in a 1-2 shift. Its pretty much shot, no more racing...
Now, my question is, i know theres alot of different clutches out there, im not looking for a racing clutch or something that will shatter my tranny, but i need something that will at least hold this 50-shot, later to be a 75-shot. Are there any clutches you guys can recommend that are running that much power?! Any sites, prices, experience and everything is appreciated. This is shiiiiiiity!!!
Eric
Old Aug 17, 2003 | 02:53 PM
Keith97gxe's Avatar
i have an exedy and i should have nitrous going by the end of this coming week so i can let you know how that holds up
Old Aug 17, 2003 | 03:11 PM
1FSTMAX's Avatar
I'm using a ACT steet modified clutch. It hold a 50 shot with no problems.
Old Aug 17, 2003 | 03:23 PM
guestNX's Avatar
act street (part number NM1-HDMM) would be a good one for the amount of power you were talking about. just don't be stupid with it (shifts). It lists for mid 300's , and can be purchased for upper 200's
good luck
Old Aug 17, 2003 | 04:36 PM
EteRnity059's Avatar
Boosted?....
I love my EXEDY Stage one Clutch. I have no chatter or any problems with it. I am also running a fidanza flywheel and have not driveability issues. Though I am not running nitrous... I can chirp third if that helps...
Old Aug 17, 2003 | 05:15 PM
good luck
Thanks alot for the part number, and where can you purchase it for upper 200s?
Eric
Old Aug 17, 2003 | 05:42 PM
whats the part number on that clutch?!?
Eric
Old Aug 17, 2003 | 05:50 PM
Boosted?....
Eric
I'm not sure...but I got it from Maxtunningusa when he had a group deal on it. It is the stage one organic clutch, not the ebay one.
Old Aug 17, 2003 | 07:11 PM
95emeraldgxe's Avatar
i hear alot of good things about the act clutch, the exedy is the manufacturer of the OEM clutch
Old Aug 17, 2003 | 07:16 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Eric you dumb kid, you will need 100hp/120tq via a 100 shot to keep up with MEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE.
MWUAHAHAHAHAHHAHAHAHAHAHHAAH
Old Aug 17, 2003 | 07:31 PM
keep telling yourself that craigy. Mind you, im running a 14.5@97 with a SLIPPING clutch. Id say its good for a 14.2-ish run. Let me get my B-pipe, FPR, Walbro, UDP and up it to a 75 shot, and we'll see who wins this battle...
And thanks eternity059...I look into that one...
Eric
Old Aug 17, 2003 | 08:27 PM
Craig Mack's Avatar
well....well.....my ***** is bigger than yours. AND i have a snail that makes weird chirping noises that attracts mondo attention.
Erics car with 50-75 shot of ***** juice, rice sauce, cheater gas < Craig Mack Blown at 10psi
Old Aug 17, 2003 | 08:30 PM
Keith97gxe's Avatar
Hey now dont be bustin on people runnin nitrous. Call it all you want but when he beats you then you wont be talkin.
Old Aug 17, 2003 | 08:47 PM
EXACTLY....
Eric
Old Aug 17, 2003 | 08:52 PM
Dev's Avatar
Dev
im sure a stock clutch can easily handle a 50 shot
its just that yours is worn out...
Old Aug 17, 2003 | 10:02 PM
1FSTMAX's Avatar
Erics car with 50-75 shot of ***** juice, rice sauce, cheater gas &lt; Craig Mack Blown at 10psi
You still don't have one thing though that Nitrous gives you. Can you say torque?
Old Aug 18, 2003 | 06:21 AM
maxcross's Avatar
Yeah, if you don't have to stop to drop your tranny and clean out all the shavings from a burnt stock clutch like the originator of this thread.
Old Aug 18, 2003 | 06:25 AM
Sprint's Avatar
i ran 100 shot with my ACT.. my clutch is fine
too bad Craig's car will never see 385ft/lbs tq
Old Aug 18, 2003 | 07:14 AM
Ceasars Chariot's Avatar
Old Maxima Legend
what about the regular duty Centerforce Clutch 30% more grip than stock, i thought I may try if one day!
Old Aug 18, 2003 | 07:24 AM
96BLUMAX's Avatar
There is also of just getting the clutch disc if you have a heavy enough pressure plate. I got mine for 89 bucks.
Old Aug 18, 2003 | 07:30 AM
Sprint's Avatar
make sure you buy 3 because they slip after 15k miles
Old Aug 18, 2003 | 12:45 PM
My tranny never broke or anything, i dunno what your talking about. All i mentioned is that i spun the **** outta it and i cant spray anymore. My car still works fine, i can drive it normally. I just need a new clutch...
My tranny wont break on a 75-shot, let alone a 50-shot...
Eric
Old Aug 18, 2003 | 01:50 PM
Jason R's Avatar
aka UNCDooD
Eric
don't be too confident in the tranny. mine broke and all I have is y-pipe and intake.
Old Aug 18, 2003 | 02:23 PM
Very true. God forbid anything like that happens, i do have an extended warranty that covers my engine and tranny. So hopefully it would be taken care of...
Im also gonna look into whether or not it covers my clutch...never know...
Eric
Old Aug 18, 2003 | 03:59 PM
Also, my dads insisting that i should just change my pressure plate and it will be all good. But those run upwards of 100 bucks, so shouldnt i just get an Exedy clutch kit and replace everything on one shot since i already have 88K on my tranny?!?!
Eric
Old Aug 18, 2003 | 05:20 PM
1FSTMAX's Avatar
Eric
Yeah replace everthing, and resurface the flywheel or replace it.
Old Aug 18, 2003 | 05:23 PM
About how much does resurfacing one cost?!
<<New to the tranny stuff...
Eric
Old Aug 18, 2003 | 05:29 PM
Craig Mack's Avatar
Did you ever get those dual exhausts? I remember you PM'ing me about it a while back. Let's see some pics...or do you still have a single fart-back?
1FSTMAX:
Look at those two beasts leading the way, with all the small displacement rice behind them. True small block beasts with tiny blocks behind them.
Old Aug 18, 2003 | 05:30 PM
Craig Mack's Avatar
&lt;&lt;New to the tranny stuff...
Eric
I got mine done for $40.
Old Aug 18, 2003 | 05:31 PM
RastaManMax's Avatar
385?!?!
Old Aug 18, 2003 | 05:32 PM
1FSTMAX's Avatar
1FSTMAX:
Hahahah I have video of me beating the Corvette in the 1/4 mi.. I decided against dual exhaust, there is no point other than extra piping and added weight.
Old Aug 18, 2003 | 08:10 PM
Keith97gxe's Avatar
Post the video
Old Aug 18, 2003 | 10:16 PM
1FSTMAX's Avatar
Post the video
Team STILLEN
Aug 10, 2015 04:29 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
