FYI.. NAPA has T-bolt clamps for $2.99
Old Aug 18, 2003 | 10:28 PM
Bags's Avatar
VG Ridah's Biatch Hoe
They are under heavy duty clamps section in there little parts book, called either T clamps or T-bolt clamps
They have from 2 1/2 inch to 4 inch inside diameter for $2.99
Old Aug 18, 2003 | 10:37 PM
BigDogJonx's Avatar
Do we have to order these or can we pick them up at the local store? I gotta get some since the car is under the knife bigtime.
Dixit
Old Aug 19, 2003 | 10:36 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
just to let yall know, its not local like NAPA, but if you need smaller sizes you can get them here-->
http://www.partssystems.com/shop/pro...egory_id=TBOLT
I got my 2" clamps from them, $2.30 each.
Old Aug 19, 2003 | 10:44 AM
Bags's Avatar
Dixit
You can get them at the store if they are in stock, if not they are in the warehouse off of 85N.
Next day you can pick them up OR you can go to the warehouse and get them
Da-max- yeah I found them cheap as well.. but this is for that OH SHOOT I need spme T bolt clamps NOW..lol
Old Aug 19, 2003 | 10:48 AM
DA-MAX's Avatar
oh so its one of those times, I've been there before
Old Feb 12, 2005 | 08:44 AM
I30tMikeD's Avatar
I don't know why I am having a hard time with this but I want to make sure I get the right size T-bolt clamps. The effective range of these clamps seem to be so small.
For example, my intercooler piping is 2.5" so I would think I need 2.5" T-bolt's for those connections but, for example, if I look at www.summitracing.com their application for 2.5" T-bolt clamps is a range 2.31 to 2.62. Obviously I am not going to clamp below 2.5" since that is the OD of the piping. Then add on the extra diameter because of the silicone coupler. So 2.62 may not even be wide enough to get the T-bolt over the coupler. So for summit racing's application should I go with their 2-3/4 T-bolt which has a range of 2.69 to 2.87.....then I think that I may not be able to tighten it enough since the smallest it will go is 2.69.
There is also www.partssystems.com which, for example, lists their 2.5" T-bolt with a range of 2.5''-2.81''. This seems like it would work better.
Then their is Atpturbo.com which says go with a 2.75" T-bolt for 2.5" piping
I guess I could just say F-it and go to Napa to make sure I have right size.
Old Feb 12, 2005 | 10:51 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
i hear you mike, thats what i think i'm going to do when i redo the install
Old Feb 12, 2005 | 11:29 AM
95turbo gxe's Avatar
yeah I got this one pipe that keeps poping loose so ill check that out monday. And ill try to rough up the out side of the pipe too. That way just maybe it will stay.
Old Feb 12, 2005 | 05:12 PM
hlh0501's Avatar
My experience with NAPA t-bolts, is typically needing the next size up. Ex. 2.5" pipes needing 2.75" tbolt.
Also, when I have asked for "T-Bolt clamps" they have no idea what I speak of. Ask to see the catalog of 3" pipe clamps, and just point out what you want
Old Feb 13, 2005 | 11:40 AM
Stephen Max's Avatar
Boost hose is typically .125" thick. So, if you have a 2.5" pipe, you are going to need a clamp that will open to 2.75". Likewise, for 3" piping you need 3.25" clamps.
I have a bunch of 3.125" clamps that are useless because I can't get them over the 3" boost hose.
Old Feb 13, 2005 | 08:41 PM
1MAX2NV's Avatar
What size is the Stillen SC pipings?
Old Feb 13, 2005 | 09:16 PM
slimer's Avatar
i think that its 2.5
Old Feb 14, 2005 | 01:16 PM
crewchief264's Avatar
For a 2.5 inch pipe you need to go to napa and get the one has 2.75 stamped on it- they are the one I use they are like 2.80 or something.
maxima297
Sep 24, 2015 08:57 PM
iamute
Sep 20, 2015 05:22 PM
followthadollar
Sep 13, 2015 09:55 AM
pjgreek
Sep 9, 2015 09:30 PM
boomerbrian
Sep 2, 2015 03:46 PM
