EVAP canister purge control valve/solenoid valve
Old Aug 20, 2003 | 07:00 PM
bobjohnson's Avatar
Blazin......
OK Round #3.
Ive had this ecu code for 3 months now.
No one can seem to help me out though. I drive a 95 Maxima, AUTO, SE.
-There are 3 items.
1- purge control valve
2- solenoid valve
3- purge solenoid valve
-There not behind the rear wheel at all
- I cant find them under the hood, BUT i do see the canister.
- I do follow the canister but theres actually a little round thing on top of the canister. 1 hose goes to something near my EGR parts.
The other hose goes to the tb or in some part of it.
ANY HELP IS APPRECITAED.
btw, the online chiltons manual<--i ve seen/read the entire thing, yet still WHERE it Points to UNder the Hood. NOPE, not there
>I did find this electrical part with 2 hoses connected to it. Im not sure which one it was but i did clean it off and put it back on.it was close to the front , on the right next to the head cover.
Old Aug 20, 2003 | 08:20 PM
bobjohnson's Avatar
Blazin......
bump.
Old Aug 22, 2003 | 04:56 PM
bobjohnson's Avatar
Blazin......
bump, anyone w a 95 and any evap probs?
Old Aug 23, 2003 | 08:06 AM
bobjohnson's Avatar
Blazin......
bump. njseltedmax <- man if you can plese gimme some more insight. Your knowledge is appreciated
Old Aug 23, 2003 | 08:16 AM
Kevlo911's Avatar
Kevlo for President
Diagnostic Trouble Code 0807 does not appear in the '99 Maxima factory service manual, and that is my principal information source. I'll tell what I know about the '99 Maxima EVAP Canister Purge Volume Control Solenoid Valve. This information may or may not apply to your Maxima.
The Evaporative Emission (EVAP) Canister Purge Volume Control Solenoid Valve uses an on/off duty cycle to control the flow of fuel vapor from the EVAP canister. Diagnostic Trouble Code 1008 is set when the Engine Control Module (the computer) detects an improper signal through the valve. The problem is likely to be in the electrical wiring, harness, or the valve itself.
Check fuse #58 (10 amps) and replace if necessary.
The CPVCSV is easy to see and reach. It is located in the engine compartment, mounted to the top of the upper intake manifold. Notice the Vehicle Serial number stamped into the firewall. Put your finger on the third-from-last number. Move your finger three inches toward the radiator. That's the CPVCSV. It has one two-wire electrical connector and two vacuum hoses.
You may test the valve. This test procedure is performed with the engine off. Remove the electrical connector and both vacuum hoses. Fasten a length of clean rubber vacuum tubing to either nipple. Gently blow through the hose. The valve should be closed and it should be difficult or impossible to send air through the valve. Now use a pair of fused test leads to provide 12 volts to the electric terminals. The polarity doesn't matter. With the solenoid energized the valve should be open and it should be easy to send air through the valve.
from ecu codes defined
Old Aug 23, 2003 | 08:31 AM
bobjohnson's Avatar
Blazin......
wow!, well thanks alot.
>> Are u referring to a 99 maxima or 95-96, they are different.
Old Aug 23, 2003 | 08:35 AM
Kevlo911's Avatar
Kevlo for President
http://forums.maxima.org/showthread.php?threadid=235667
thas where that came from, DBM defined all the codes and i just found them for everyone to use again. but they should be close to the same, what codes are u getting?
Old Aug 23, 2003 | 08:48 AM
bobjohnson's Avatar
Blazin......
0806 EVAP canister purge control valve/solenoid valve
there are no codes for this problem, thats just my luck ya know.
http://forums.maxima.org/showthread....5&pagenumber=2
Old Aug 23, 2003 | 08:55 AM
Kevlo911's Avatar
Kevlo for President
http://test.maxima.org/search.php?searchid=10463
that might help
here are all the ecu codes that have to do with the EVAP, maybe they will help you
0312,0807,0309,0111,0215,1008,0214,0213,0704,0903, 0705
Old Aug 23, 2003 | 09:51 AM
Dave Holmes's Avatar
For a '97, the EVAP canister purge control valve is located on top of the intake manifold (upper), to the left of the TB when looking from the front, and just behind the throttle cable adjustment. It's a black round plastic part in a holder similar to the kind that holds the fuel filter. It has 3 vacuum hoses going to it.
To test (from '97 FSM):
1) Blow air in ports A, B, and C and ensure that there is no leakage.
2) Apply vacuum to port A (approx -3.94 to -5.91 inHg). Then blow air in port C and ensure free flow of port B.
When looking at the part in your hand, have the single vacuum port at the top left(port A). The larger port below A is C, and the port on the bottom right by itself is B.
About the only thing that can go wrong with this part would be for it to be stuck, or a leak in a vacuum hose.
The EVAP canister purge control solenoid valve is located next to the MAP/BARO switch solenoid valve. They are located to the right of the front valve cover (looking from the front), and underneath the big wiring harness. The EVAP is the one with a single vacuum hose coming from the top, and two from the bottom. The other is the MAP/BARO, which is the opposite as far as vacuum lines. The EVAP has a black connector, and the MAP/BARO's connector is brown. There is a way to test the valve with battery current on page EC-231 of the FSM ('97).
Email or PM me if you need actual pics from my engine or pages from the FSM.
Keep in mind my car and FSM are both '97s, so your car may vary.
Dave
Old Aug 23, 2003 | 10:50 AM
bobjohnson's Avatar
Blazin......
YES YES Please . Send me pics of anything or everything with the EVAP , I have NO idea what anything looks like but if i had a pic i could really find out where its at.
My email is mikemikeinstl@yahoo.com
Please send me a link or a pic from somwhere.
Thanks dave, btw i read like 20 of ur posts about the EVAP,
Tell me something. It is different from 97-99 right?
I have a 95 Auto, but NOT even my dealership knows where the problem is..
THanks in advace dave. mwest
Old Aug 23, 2003 | 11:32 AM
mwest,
Info will be on its way shortly.
Dave
Old Aug 23, 2003 | 12:20 PM
bobjohnson's Avatar
Blazin......
thanks dave. any other information to located the parts on a 95 Is appreciated.
Old Sep 15, 2003 | 07:43 PM
chiwchan's Avatar
I replaced the valve and continue to get the 1008 code after ECU resets. Do I have to disconnect the battery.....
Is fuse #58 located next to the battery? (I'll have to check this)
Also, if I need a replacement harness, what would be the part number and where can I get this?
Old Sep 16, 2003 | 12:45 PM
chiwchan's Avatar
Does anyone have this problem for a 95 Maxima?? Just checked fuse and its okay...
Old Sep 16, 2003 | 03:24 PM
Max96GLE's Avatar
0807 and 0903
I got the 0807 and 0903 code. My CEL doesn't stay ON like all other codes. It's ON and OFF once a while, so i'm not sure what's the problem with my EVAP. Once a while, when I starts the car. The CEL could be ON and could be OFF. My ECU is spitting only the two codes.
Max 96 GLE
gavin68
Sep 18, 2021 12:36 PM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
