anyone swap gauges from black to SE white's? also have needles questions...help
well i have indiglo gauges but they stick and i can't fix them. i've tried 3 times, hate it. so, i bought some stock white gauges and was gonna just remove the old ones with indiglos over it by cutting them out, but then i realized the needles won't fit over my new stock ones. anyone know a safe way to remove the needles? or have any ideas for me...can't get the damn needles to not stick, tried double sided scotch tape, super glue, nothing works. they still stick. i can't find any decent instructions on this either, so hopefully someone can help!
Re: anyone swap gauges from black to SE white's? also have needles questions...help
wJ
I think there might be instructions somewhere with the intelliglow needles stuff @ importintelligence.com too.. dunno though
if your needles are sticking to your indiglo gauges (i had this problem), i jus sanded the back of my needle base, so it didn't rub against the gauge face. you could use a nail filer, jus becareful not to scratch the gauge surface (i had a double sided filer, and i taped up the side rubbing against the gauge). and jus sanded down the black base of the needle a little bit, no one can even tell because the sanded part is on the back of the black **** thing that the needle comes out of.
http://forums.maxima.org/showthread....hreadid=163819
Check that out. See the links in the first post.
doctorpullit
Sep 10, 2015 06:33 PM
