MEVI and SC
Old Aug 22, 2003 | 07:18 AM
ejj's Avatar
ejj
MEVI and SC
What RPM have you guys found is the best for the switchover point? I used 5000 RPM, but some of the NA guys (Neal and Dave) suggested 5300 RPM or so.
I haven't been on a dyno yet, but was wondering what you guys found as the best.
Old Aug 22, 2003 | 09:39 AM
JAY25's Avatar
I just switched to 5100 feels good
Old Aug 22, 2003 | 11:21 AM
Stephen Max's Avatar
Re: MEVI and SC
I have mine set to 5300 rpm based on Neal and Dave's recommendations. When I dyno this winter I'll experiment a little.
Old Aug 22, 2003 | 11:23 AM
ejj's Avatar
ejj
Either of you guys tried it at the track and played with the settings there?
Old Aug 22, 2003 | 11:37 AM
No.
Old Aug 22, 2003 | 11:51 AM
iansw's Avatar
I've done 18 or so Dyno runs, setting it at 100RPM increments down to 4400 and up to 5800.
5000 works best for me every time. But some people have gotten different results.
Old Aug 22, 2003 | 11:54 AM
ejj's Avatar
ejj
Was that when you were an auto or 5sp?
Old Aug 22, 2003 | 11:56 AM
iansw's Avatar
Hmmm....
You're a genius, ejj!!!
I Dynoed but didn't even think to mess with the RPM Switch at the time. maybe that epxlains some hp loss....
(I was Auto)
IanS
Old Aug 22, 2003 | 11:59 AM
ejj's Avatar
ejj
Yeah, I get that a lot.
Old Aug 22, 2003 | 12:05 PM
96shogunmax's Avatar
So I should set it higher than 5k?
Old Aug 22, 2003 | 01:56 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Can you FORCE the switchover at low RPM?
If so, dyno withOUT and with(say 2000rpm-redline) MEVI activation and set switchover to occur where the two TORQUEs cross.
Old Aug 22, 2003 | 04:51 PM
AllGo's Avatar
When i was s/c i had mine at 5100 and there was a small hiccup in the hp/tq line when I dynoed 326whp. It recovered about 5400 so I have since changed to 5300 and the switchover is much smoother. I am not boosted anymore and neal and dave both like 5300 and it sounds right, so I am staying here.
Old Aug 22, 2003 | 08:04 PM
speedemn's Avatar
Re: MEVI and SC
I have an NA motor and I dyno tested the optimal RPM switch point and 5200RPM worked out the best for me.
Old Aug 24, 2003 | 04:17 AM
nismo2020's Avatar
Needs non-Maxima Friends
what did you do with your blower?
Old Aug 24, 2003 | 05:16 AM
SteveChicagoSC's Avatar
I lost 55hp when I opened it at 4500 rpm. At 5000 rpm I lost 20hp. I also found 5300-5400 rpm was the best place to open the vi.
Old Aug 24, 2003 | 05:44 AM
JAY25's Avatar
he sold it
Old Aug 24, 2003 | 08:05 AM
AllGo's Avatar
Originally posted by JAY25
he sold it
Thanks Jaime, Yeah I really liked the power and was actually planning a fmic in order to use a smaller pulley and get some better torque numbers. The blower seemed to be very sensitive to belt tension and I think the internals were starting to wear after only 20k miles. I will prob just turbo my car within the next 6 months or keep it for another year and then get the awd G35 or maybe an EVO.
Old Aug 24, 2003 | 11:33 PM
iansw's Avatar
Well, I set it to 5300RPM today.
At the same time, however, I fixed a boost leak.
So it seems faster, but I don't know if it's the switch or the leak.
I'll play with it some more next weekend. I don't drive during the week.
IanS
Old Dec 5, 2004 | 12:04 PM
michaelnyden's Avatar
now is this 5300rpm's as indicated on the tach....or as seen on a OBD scanner or something more accurate...like a digital readout from the ecu's rpm wire?
looks like the consensous is that 5300rpm's is optimal...doesn't it take 100rpm's to complete the switchover? so it is finishing at 5400 then? and that is optimal...no dip in graph? or would I set it at 5200 and it opens completely at 5300?
Old Dec 5, 2004 | 01:38 PM
Nealoc187's Avatar
SLOW
5300 (or 5400 whichever you choose) is the setting on the RPM switch, all tachs seem to read differently so setting it by the tachometer wouldn't make much sense.
litch
123
Jan 4, 2024 07:01 PM
maxprivate
Nov 29, 2017 08:52 AM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
BkGreen97
Apr 2, 2016 05:47 AM
lrb6805
Sep 30, 2015 08:12 AM
