BOV Basics??
Old Aug 26, 2003 | 12:44 PM
crewchief264's Avatar
BOV Basics??
I am wondering if anyone can tell me the basics of the greddy type s bov, I know a bov is there to make your supercharger last longer and to bleed off psi. I just wanna know how I should set mine up in my car when I install the sc? I have a 5spd and almost always when running hard shift at 6000-6200, I am planning on running 9psi.
Old Aug 26, 2003 | 12:47 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
BOV doesn't bleed boost...it lets air out of the charge pipes to prevent backflow into the TC/SC under vaccum
and if you did "bleed" it using that method the car would stall out, thats like a psuedo air leak of sorts
Old Aug 26, 2003 | 01:24 PM
96BLUMAX's Avatar
Yeah what he said. Also you need to think about if you want the blow off just to be released or inserted back into the intake path. By the way, how does the BOV sound when it reverts back to the intake instead of just blowing straight off?
Old Aug 26, 2003 | 01:33 PM
dont know
I don't have the sc yet and it isn't installed yet. what should it sound like? what is the cycle? I mean what sounds should it make ie half full and no throttle, in say third gear. should I put the air back into the airflow, and if so where at?
Old Aug 26, 2003 | 01:42 PM
96BLUMAX's Avatar
If you put it back in which helps certain things spoken in different topics on this forum, you add the pipe to before the blower. It also helps if you live in a stupid state like VA which does not allow engine gases (including blow off) escape. The BOV will blow off everytime you go vacumn so yes some times if you let off after half throttle it will blow off. Depends on if you were boosting before. Youll see once you get your boost guage in.
Old Aug 26, 2003 | 02:17 PM
[maxi-overdose]'s Avatar
I bleed off boost with greddy S BOV I only can get 10psi out of my SC from a 2.87 pulley.
I think the greddy is just known to leak and even during vaccum, it still let out some air. I believe the purpose of this is for someone who's interested in converting the greddy to a recirculate valve.
Old Aug 26, 2003 | 02:19 PM
96BLUMAX's Avatar
Yeah i would guess that is why it has a thread port on it for the blow off.
Old Aug 26, 2003 | 02:38 PM
Re: dont know
check out this link for sound clip from different brands of BOV.
http://www.blowoffvalves.com/
Old Aug 26, 2003 | 04:09 PM
is that what it is
so is that greddy type s bov sound like that on our cars also. if so I can't wait!!
Old Aug 26, 2003 | 08:53 PM
Re: is that what it is
the link doesnt seem to work...
here's the old site.
http://alltrac.net/tuning/blowoffvalve.html
Old Aug 27, 2003 | 07:02 AM
96BLUMAX's Avatar
Good site!
gavin68
Sep 18, 2021 12:36 PM
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
Dasmith
Sep 23, 2015 08:28 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
