Anybody know how to bypass the SC?
Old Aug 26, 2003 | 06:02 PM
na95gle's Avatar
I was wondering if any of you had a diagram or directions to bypass the SC. I figured I might as well do this and pass smog since the blower is already out of the car. Thanks guys, any help would be appreciated.
Old Aug 26, 2003 | 09:02 PM
[maxi-overdose]'s Avatar
hmmm...put the stock tensioner pulley assembly back on and use the stock belt. or you can just use stillen's tensioner bracket and pulley, but use a shorter belt instead.
make sure you put all the bolts back to the timing chain cover or it will leak oil. Since all your MAF/sensor are on the charger pipe, so just attach a filter onto the charger pipe and you are ready to go.
you are in Fremont, right? where are you planning to get smog check? I am in Fremont too and my smog is coming up next year. do you have any hook-up?
Old Aug 26, 2003 | 10:26 PM
iansw's Avatar
The SC is 50-state legal, I thought.
I passed emmissions with my V1 squealing away with no problems...
Old Aug 26, 2003 | 10:52 PM
na95gle's Avatar
maxi-overdose:
Yep, I'm in Fremont, pretty close to the 680/880 Mission exit. I don't have hookups ....YET. I'm gonna go check out this one place where I've been told it's 'easier' to pass. If not, i'll just bypass the blower.
iansw:
But what about those new dyno-smogs? I don't think I'd be able to pass that.
Old Aug 26, 2003 | 10:55 PM
na95gle's Avatar
I forgot, do any of you happen to know the size of the stock belt?
Old Aug 26, 2003 | 11:49 PM
Chunger's Avatar
My other car is a Hybrid
K060710 for the V2 IIRC.
Is THAT the reason you are changing the belt? The kit has a Carb EO#... I doubt they will even check the pulley size... Have them do a quick visual inspection first.
Old Aug 27, 2003 | 08:18 AM
Originally posted by na95gle
maxi-overdose:
I see...I live near Fry's, on the other side of the railroad.
good luck~ good thing that your kit is CARB legal as iansw mentioned, so you can have it on your car and you will pass visual if you follow stillen's SC installation instruction. However, if you are running rich, you will not pass the test.
have you dynoed your car? if not, see if you want to go together to ATP (on Warmspring) for some dyno runs. I might visit them in a week or two. baseline is 65 dollars for 3 runs and tuning session is 100 dollars.
Old Aug 27, 2003 | 12:39 PM
na95gle's Avatar
Chung:
Nope that's not the reason, it's starting to shred again. So I figure that I might as well just bypass the blower anyway since it's coming out to get the belt replaced. I also got my steel pullies so i'll be putting those in as well. Is that belt size the one I would use to bypass the blower?
Maxi:
Hey you live pretty close then. I'd be up for some dyno runs if in a couple weeks.
Old Aug 27, 2003 | 03:05 PM
Chung:
Maxi:
need help on the belt? I have been thru several shredded belts and hope my experience can help a little.
Old Aug 27, 2003 | 03:23 PM
na95gle's Avatar
Sure, check your pms.
Old Aug 27, 2003 | 04:39 PM
Chunger's Avatar
The belt listed above is for the "stock" 3.6" pulley...
tsi6001
Oct 3, 2022 10:23 PM
05' MaximaMan
Oct 8, 2017 06:36 PM
jwright36
Sep 8, 2015 11:45 AM
Slamrod
Sep 3, 2015 07:38 PM
lux97Max
19
Aug 27, 2015 07:48 PM
