Turbo 04? Could It happen??
Old Sep 2, 2003 | 01:13 PM
Glude's Avatar
Ok guys i know nobody has turboed an 02 or 03 or even an 04. Would it be very hard to put together a turbo setup for my 04? I really wanna boost the max since the motor seems pretty strong. Anyways I guess the only way to do it would be a custom setup. Can anyone give me some input on this and possibly a price range of what I could be looking at. Thanks boosterz!!! later
Old Sep 2, 2003 | 03:02 PM
PCGuRu2K's Avatar
Anything is possible... It's just a matter of, is there enough space to play in?......
Old Sep 2, 2003 | 03:22 PM
Shadow's Avatar
No reason it couldn't happen. It would have to be custom, but it's possible. Price range depends on a lot of things. How crazy of a setup do you want?
We recently did a custom turbo for a 98, and are researching making one for the '03, and it honestly doesn't seem that much harder than the '98. Obviously there are more electronics in the way, and a little les room to work with, but nothing that would block the project.
Isn't the '04 the same motor as the 03? and 02? How much space is under the hood? I've never looked at one.
Old Sep 2, 2003 | 09:44 PM
Glude's Avatar
Well Im pretty sure there is a decent amount of space under the hood. I want a setup that I can run a safe amount of boost say 5-7 psi on the street, but able to turn up the boost at the track to around 10-12 psi or some. I wanna make around 300 whp running around 7 psi or less. I really want it to be a reliable setup since this would be the first turboed car i would own if i plan to do this. anyways see if this helps and get back to me whenever you have time. thanks!
Old Sep 2, 2003 | 09:51 PM
Shadow's Avatar
300 whp at 7 psi on an '04 should be easy. Since you're probably at 220+ whp already, an 80 hp gain isn't hard. We gained 91 whp on a '98 at only 5 psi. So 7 psi on the 3.5L would be closer to 350 whp or more.
I have no idea of the reliability of the 3.5's under boost only since it hasn't been done yet. But I don't think there would be too much problems.
Where are you located?
Old Sep 3, 2003 | 02:25 PM
Glude's Avatar
Im located in Tyler,Tx. Im about 2 hours from dallas.
Old Sep 3, 2003 | 02:59 PM
mtcookson's Avatar
actually the 3.5 has been boosted. the 350z has s/c and turbo kits out now.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Need help
23
Oct 2, 2015 08:56 AM
09maxshawn11
Sep 30, 2015 10:28 AM
