Solobaric L7 with a Rockford 700s???What do u think?
I have a L7 Kicker 12" Sub and im deciding on a 700s the older model of Rockford amps. The L7 12" RMS is 750, and the Rockford Amp RMS is 700...Would that work? Or will i damage my sub? How does it work out when deciding how much power is enough or too much for a sub? And where does the ohm's come in? What if the sub is either 4 ohm or 2 ohm? what does that do for me? Thanks for all the input im clueless...one
that RF amp will put out more than 700 watts. it would like like 730 - 750 (perhaps more) in true wattages. my RF amp pushed out 45 more watts than listed. it should tell you on the amp's birth certificate
I heard the same thing about rockford...But when it comes down to haveing the right amount of power...how much watts should i consider for a solobaric L7 that runs 750 RMS? Should it be as close to 750 as possible? What if i run too little or too much power ?(watts)?
Originally Posted by D1NOnly34
RF amps usually put out way mroe than advertised, i have a 700s and it pushed around 830 watts, i have 2 12" HE2s, but am switching them with my new L5's, should be a good combination
Thats cool, but if my sub is 750 RMS would that 700s running around 830 be too much for my sub? or could it work? Or should i run less power to one 12" L7?
is that amp rated at 700 peak ? most amps say they do 700w. but really only do the peak w when bridged @ 1 ohm. L7s can do 750rms, means they can handle about 11-1200 w peak. i hear L7s love power. enjoy your thump, your **** is gonna bump!
i have 2 L 7 12' and my car is almost falling apart those things are a loud and RF is a very good amp and by the way is beather to take more power full amp than less i am about to change my Kicker 02KX800.2 coz that s**t sucks big time and what ever you do dont take kicker amp what do you think i should get ?
bryants95max
Oct 2, 2015 12:52 PM
