The Moment has Arrived: DDE Lightning™ STRIKES!
IF you guys are interested in this, we will make it for the Maxima.
No, the camera is not playing tricks these are literally white/blue look.
Are they brighter than Gen V? NO.
Are they the same as Gen V? NO.
Just read through it and tell us if you want it made for your cars or not
want more?
DDE Lightning™ Plus
Positives
Very Bright/Neo Modern Look
Pure White
No Light Box
Easy fit
Inexpensive $169 <--- price edited.
Fits all applications currently available*
Upgradeable to Enhanced™ <-- later release date
Fits E36, E38, E46 and OTHER**
*Recommend Professional Install
** Inquire @ info@umnitza.com
Precautions
Relatively fragile
Has mercury in it, small doses, but still mercury
Not "classy" OEM look
Still generates heat 80-100 degrees - heat generation is near the Headlight, no known long term effects.
Minimal Cold Climate Startup difficulty
No different colors available.
By comparison, here's Gen V.
want more?
DDE Lightning™ Plus
Positives
Pure White
No Light Box
Easy fit
Precautions
Relatively fragile
I think there cool looking on the headlights and all but not digging the fact there not full circles. I can understand our high beam cause that goes to the top of the housing but not the HID one. All and all I like them just not going to take apart my headlights to do it.
Originally Posted by umnitza
Easy fit
Inexpensive $129
Only $129....I'll buy RIGHT NOW!
--This is what I wanted....the BLUE/WHITE color
U da man
So when u gonna be done testing these so we can buy?
umnitza, Whats the difference between the DDE Gen V that you made for us 02-03 owners and the DDE Lightning™ Plus??? No light box??? How do you get the rings to light up??? Why are the DDE Lightning™ Plus
cheaper than the DDE Gen V that you made for us 02-03 owners???
Ok, some answers - one, I goofed on the price BIG time, sorry to lead you guys astray.
The price is $169. The problem with posting so late is that the fingers do more work than the brain.
After re-running the numbers. There is no way we will keep the $129 price point. It's simply too low.
There are a lot of differences, most of them listed in the positives and negatives.
The key is that Gen V is proven to work over many different terrains, can change colors, is easy to install, and doesn't break.
This technology is more inexpensive but not necessarily brighter in the classic definition of it (lumens) but to the eye, blue light scatters more, so it appears brighter.
Why is this cheaper, because there is NO WARRANTY on this stuff. Gen V has a lifetime.
You break it, tough bananas
What we haven't figured out yet is this:
Gen V allows the fit of the ring to be friction fit into the reflector, but these rings have no flex. So, it's likely to be a glue only solution. YUCK.
ANy other questions should be answered in the FAQ that we are completing.
what kind of glue?
....also how does the Gen V attached onto headlights?
00 max?
ya same question...on the website it says its going for 250 so is it still 169? and i wouldnt be able to put it on my 00 max unless i get 02-03 headlights huh? or is there an alternative that isnt that expensive....i want those DDEs man!! they look so pimp~!
James92SE
142
Jan 2, 2024 09:23 AM
