What fuel pressure I should see with the SC?
Old Sep 15, 2003 | 02:39 PM
Max4Speed's Avatar
www.autotalk.com
I think I am running around 1 kpa.... No clue?
Old Sep 16, 2003 | 03:43 PM
[maxi-overdose]'s Avatar
what pulley and what FMU disc do you have?
Old Sep 16, 2003 | 04:44 PM
Max4Speed's Avatar
www.autotalk.com
3.125 and a 6.1 disc.
Old Sep 16, 2003 | 07:08 PM
MAXIN's Avatar
Is that at idle? Where did you T into the fuel line? You should be T'd between the fuel filter and fuel regulator. You may be T'd into the fuel return which is a low pressure line.
Old Sep 17, 2003 | 07:37 AM
Max4Speed's Avatar
www.autotalk.com
I think thats what it is. Thanks for the help guys :-)
Old Sep 17, 2003 | 09:06 AM
is 1Kpa = 7psi?
you should get about 11psi from your 3.125 and your FMU is 6:1.
assuming your base fuel pressure is 38 if u dont have an aftermarket FPR.
so....
fuel pressure at boost = peak boost pressure * FMU ratio + 1/2 * (base fuel pressure)
FP = 11* 6 + 38/2
= 85psi.....
how come you have 6:1 with a 3.125? that's kinda low for a small pulley like 3.125.
Old Sep 17, 2003 | 11:51 AM
Craig Mack's Avatar
All YOUR grammer belong to me
Yea....a 6:1 Disc is really risking it with a 3.125 imo. Couldnt that starve the engine/cause detination? BOOM.
Old Sep 17, 2003 | 12:39 PM
Stephen Max's Avatar
is 1Kpa = 7psi?
Actually the conversion factor is 6895 Pa per psi, so 1kPa is pretty close to nothin'. I think either the gauge isn't hooked up right or the pressure transducer is on the fuel return line, like Maxin said.
Old Sep 18, 2003 | 09:36 AM
Max4Speed's Avatar
www.autotalk.com
Thanks Ramius for hooking the gauge rite this time ;-)
Car is idles at 36.25 PSI and I did peak it at 52.20 PSI. Is this a justification to go for 8:1 disc? Still trying to learn this boost stuff :-)
Old Sep 18, 2003 | 10:05 AM
idle seems right....but peak is way too low, make sure the vacuum hose connect to the FMU is not leaking. how's your EGT?
even with a 6:1, you should get at least 80psi of fuel with your pulley. what fuel pump are you using? if it is the aux pump, make sure it is wired correctly.
8:1 is a must for a small pulley like yours. IMO, the kit should come with an 8:1 instead of 6:1. Stillen uses 6:1 for the 3.60 pulley because they dont want to maxxed out the stock injectors. But it's either pushing your luck and pray that the injectors wont lock-up or running super lean all the time.
Old Sep 18, 2003 | 10:46 AM
Max4Speed's Avatar
www.autotalk.com
Now the question is how can I check the peak. Peak should be at maximum boost correct?
EGT maxed out at around 750-800 C. I have the walbaro fuel pump. Kit came with 8:1 but Bosco had 6:1 on it.
-OS
Old Sep 18, 2003 | 11:42 AM
Max4Speed's Avatar
www.autotalk.com
Just went for a test drive again but freakin traffic sucks downtown.
I was able to get to 8psi boost, 76.85psi Peak FP and 700ish C EGT.
Comments?
Old Sep 18, 2003 | 11:47 AM
Comments?
looking good. did you pull from dead stop or from rolling?
8 * 6 + 36/2 = 66psi <---- that's the fuel pressure that you supposed to get.
It doesnt surprise me that you get more fuel p. because I got way lot more on my 8:1 as well.
Old Sep 18, 2003 | 01:10 PM
Max4Speed's Avatar
www.autotalk.com
I pulled it from dead stop and then also from roll. So am I alrite with 6:1 disc? or you want me to do some more runs ;-)
Old Sep 18, 2003 | 01:56 PM
a dyno run will be nice.....if you are running rich, your are fine.
Old Sep 18, 2003 | 08:38 PM
Max4Speed's Avatar
www.autotalk.com
http://forums.maxima.org/showthread.php?t=249395
Old Sep 26, 2003 | 04:31 PM
bosco500's Avatar
I know this is an old post, but just so everyone knows, the stock injectors are 'supposed' to lock up at 110 psi. If you run a 8:1 disk with a 3.125" pulley, your asking for trouble. The math is easy to do. The safe way to go about it, would be getting 370cc injectors and do some tuning on the dyno with the s-afc. I just dont want oss going and blowing his motor up.
Old Sep 26, 2003 | 04:35 PM
Max4Speed's Avatar
www.autotalk.com
Thanks bosco! I am still not sure wth is going on. I guess I need to take the max to get dyno tuned so I know wat a/f i am running.
Old Sep 29, 2003 | 12:14 PM
they didnt give you an AFR from your last dyno?
Old Sep 29, 2003 | 12:30 PM
Max4Speed's Avatar
www.autotalk.com
Now when I think about it.. they should have :-\
Old Sep 29, 2003 | 02:22 PM
that's true and I agree with ya! I have been pushing more than 110 psi to my injectors near the red line and I am very concerned about this. However, 3.125 has to go with 8:1 for people like me (5th gens) that have no acess to larger injectors.
my other suggestion for 5th gen peeps who have no access to larger injector is to get the adjustable FMU and FPR so you can lower your peak fuel pressure a little.
Old Sep 29, 2003 | 02:27 PM
Chunger's Avatar
My other car is a Hybrid
Actually I think you 5th Geners have more options for fuel injectors since many companies make top feed injectors...
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Forge277
Jun 13, 2016 09:26 PM
